Troubles with lclcustomdrawn in AndroidLCLTest 13 years 11 months ago #2844
  • BrianWinfrey
  • BrianWinfrey's Avatar Topic Author
I updated to version 3.0 yesterday. Well I updated first and was glad to see that the arm-android cross compiler worked. The jvm cross compile targets would not build though, so I removed the previous version and reinstalled.
After reinstalling all of the cross compilers build, but there seem to be some curiosities. arm-android seems to replace arm-linux and visa-versa in the compilers listing i.e.
Free Pascal Compiler
FPC for Linux32
cross element for arm-android
cross element for i386-win32
cross element for jvm-java
cross element for jvm-android
Lazarus IDE
Lazarus for Linux 32 (BigIDE)
When I tried to build the example I got an error that indicated arm-linux could not be found so I built the arm-linux cross compiler
FPC for Linux32
cross element for arm-linux
Lazarus IDE
I built the arm-android compiler again and tried to build the android example.
The next error was in linking.
8<
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: warning: /usr/lib/codetyphon/lazarus/examples/androidlcl/android/libs/lib/arm-linux/link.res contains output sections; did you forget -T?
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: cannot find /lib/ld-linux.so.3
androidlcltest.lpr(37,36) Error: Error while linking
androidlcltest.lpr(37,36) Fatal: There were 1 errors compiling module, stopping
8<
I found a post on the Lazarus forum that indicated I needed to add a compiler option.
Project Options | Compiler Options | Other
-FLlibdl.so
This is the output in the messages window when I try to compile the example project
using either arm-linux or arm-android.
8<
Hint: Start of reading config file /usr/lib/codetyphon/fpc/bin/i386-linux/fpc.cfg
Hint: End of reading config file /usr/lib/codetyphon/fpc/bin/i386-linux/fpc.cfg
Free Pascal Compiler version 2.7.1 [2012/11/25] for arm
Copyright (c) 1993-2012 by Florian Klaempfl and others
Target OS: Linux for ARMEL
Compiling androidlcltest.lpr
Assembling androidlcltest
Compiling resource /usr/lib/codetyphon/lazarus/examples/androidlcl/lib/arm-linux/androidlcltest.or
Linking /usr/lib/codetyphon/lazarus/examples/androidlcl/android/libs/lib/arm-linux/liblclapp.so.so
/usr/lib/codetyphon/lazarus/lcl/units/arm-linux/customdrawn/customdrawnint.o: In function `TCDWIDGETSET__SHOWVIRTUALKEYBOARD':
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:357:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0x4c): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:357:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0x50): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:359:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0x68): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0x98): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0xb4): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0xb8): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0xec): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0xf0): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0xf4): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0x104): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_create$$tlazcdcustomfont+0x108): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:357:(.text.n_customdrawnint$_$tlazcdcustomfont_$__$$_destroy+0x3c): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:356:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_accumulatingdebugout$crca358b962+0x34): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:357:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_accumulatingdebugout$crca358b962+0x44): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:357:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_accumulatingdebugout$crca358b962+0x48): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_accumulatingdebugout$crca358b962+0xa0): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_accumulatingdebugout$crca358b962+0xa4): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_accumulatingdebugout$crca358b962+0xac): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_accumulatingdebugout$crca358b962+0xbc): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:356:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x38): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:359:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x6c): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:359:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x80): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x9c): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0xbc): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0xc4): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x100): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x128): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x144): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x14c): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/lazarus/lcl/interfaces/./customdrawn/customdrawnlclintf_android.inc:360:(.text.n_customdrawnint$_$tcdwidgetset_$__$$_cdsetfocustocontrol$twincontrol$twincontrol+0x158): dangerous relocation: unsupported relocation
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: BFD (GNU Binutils) 2.22 assertion fail elf32-arm.c:8098
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: BFD (GNU Binutils) 2.22 internal error, aborting at elf32-arm.c line 7273 in elf32_arm_add_dynreloc
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: Please report this bug.
The really confusing part is that when I first updated the example project built without error.
I'm not sure what to do now. Is this a bug or have I done something wrong?
Thank you.
Regards,
Brian
Troubles with lclcustomdrawn in AndroidLCLTest 13 years 11 months ago #2845
Sir, my suggestion is:
-Remove and build all from CT Center
-rebuild only arm-android element,
this element is a special arm-linux element
Troubles with lclcustomdrawn in AndroidLCLTest 13 years 11 months ago #2846
  • Aleksandar
  • Aleksandar's Avatar
  • Thank you received: 31
bsquared wrote: Hello,
-FLlibdl.so
Thank you.
Regards,
Brian
Please try to do what sternas suggested, and then read this post.
Other should look like this:
-dANDROID -Xd -CpARMV6 -FLlibdl.so
Troubles with lclcustomdrawn in AndroidLCLTest 13 years 11 months ago #2853
  • overrat
  • overrat's Avatar
Installed codetyphon v.3.0 under ubuntu 11.04 (32bit).
Have the same error when trying to compile androidlcltest:
When compiling under windows there no errors.
