Cross Compile linker error when using cthreads 14 years 6 months ago #1934
  • tony
  • tony's Avatar Topic Author
I am using the win32 version of Code Typhon and have the linux cross compiler setup and everything works
except when I try to compile a console app that uses threads. The console app has
cthreads and cmem in the uses and it will not run on ubuntu server unless I have cthreads working.
It builds and then proceeds to link and simply says "Linker Error"
I have attached a file with the message output verbosity set to all.
I have all the linux libs (gcc etc) copied to the win32 box
Anyone have any ideas on how to get cthreads and cmem working with the cross compiler?
Re: Cross Compile linker error when using cthreads 14 years 6 months ago #1935
can you post the fist 5 lines of your project?
Did you have Administrator privileges in your PC?
Re: Cross Compile linker error when using cthreads 14 years 6 months ago #1936
  • tony
Here is a example program that produces the same error:
(I do have admin rights on my PC, but I was not running the IDE as a admin at the time)
EDIT:
Just tried running the IDE as admin and it made no difference.
oh, forgot to add adding cmem to the uses also causes the linker to fail. As long as I don't use cthreads or cmem I can compile everything else with the cross compiler.
I am running on windows 7 64bit by the way.
program project1;
{$mode objfpc}{$H+}
uses cthreads,sysutils;
{ you can add units after this }//;
writeln('dfdfdfdf');
end.
Last edit: by tony.
Re: Cross Compile linker error when using cthreads 14 years 6 months ago #1944
  • tony
Success!!
I got it working.
For whatever reason if I had any paths in the project options for the libs it would not show the linker errors, so I removed all the lib paths I added and then the linker showed the actual errors and what libs I was missing.
The other key was to actually create the same path structure as on the target system for the libs.
So I now have the following on drive C:
C:\lib which contains:
crtbegin.o,crtbeginS.o, crtbeginT.o,crtend.o,crtendS.o, crti.o,crtn.o,ld-linux.so.2, libc.so.6,
libdl.so.2,libgcc.a,libpthread.so, libsqlite3.so,
c:\lib\i386-linux-gnu (containos a single file libpthread.so.0)
c:\usr\lib\i386-linux-gnu (contains a single file libpthread_nonshared.a)
Hope this helps someone else out. NOTE: this is to compile a console app/daemon, for a GUI you will need more libs for the widget set you are using, but if you follow this it should cross compile fine.
This is a huge deal as using Linux from a VM is fairly slow when compared to the cross compiler which is lightning fast.
Re: Cross Compile linker error when using cthreads 14 years 6 months ago #1945
  • tony
I just wanted to say thanks to the Code Typhon guys, your distribution of Lazarus is pure
genius and a real time saver. Keep up the great work, looking forward to the next version.
Re: Cross Compile linker error when using cthreads 14 years 6 months ago #1951
we prepare CT for
Cross build lab tests on Linux, FreeBSD and Solaris
