Library error 14 years 7 months ago #1762
  • David
  • David's Avatar Topic Author
Dear,
I try to compile for Android (from win32) and is ok if the target is a program, but if i try to create a library have the follow error
Options changed, recompiling clean with -B
C:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: warning: link.res contains output sections; did you forget -T?
C:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: cannot find /lib/ld-linux.so.3
test1.lpr(16,32) Error: Error while linking
test1.lpr(16,32) Fatal: There were 1 errors compiling module, stopping
the problem is that Android want a library and not a program into apk.
This appeare if i simple trasform "Program" in "Library" into the project source
Some solution?
note: very sorry for my bad english
Last edit: by David.
Re: Library error 14 years 7 months ago #1765
Android crosbuild element is experimental, Sir
Android Libraries is out of support, for now.
Re: Library error 14 years 7 months ago #1771
  • David
Ok thanks
Re: Library error 14 years 7 months ago #1772
  • David
A member of lazarus forum give me a solution.
If someone served the solution is as follows.......
You need to specify a path to libdl.so from Android NDK via Custom Options of project. Something like this:
-FL${LazarusDir}..\android-ndk-r7\platforms\android-3\arch-arm\usr\lib\libdl.so[code]
Re: Library error 14 years 7 months ago #1777
This is
the normal procedure Sir
I thought you wanted to build an android Library...
anyway here are the help steps
