Cross Compiling to Linux from Vista 17 years 2 months ago #105
  • Keith Johnson
  • Keith Johnson's Avatar Topic Author
Thanks for this great product.
I'm having problems cross-compiling to Linux from Vista.
Here is my error ->
C:\pp\bin\i386-win32\i386-linux-ld.exe: cannot find -lX11
project1.lpr(20,1) Error: Error while linking
project1.lpr(20,1) Fatal: There were 1 errors compiling module, stopping
I've also tried clean installing as Administrater too.
I have tried searching the internet on this, but it appears it's mainly goes on about Linux, the only thing I found about windows was this ->
forum.lazarus.freepascal.org/index.php?topic=5439.0
But that goes on about how cross-compiling isn't a good idea. :dry:
And how VirtualBox/VmWare was better, but I'd rather have the one development environment if possible, and keep Virtualbox for testing.
One thing I have noticed is that directory ->
C:\lazarus\lcl\units\i386-linux\win32
Has all gk2 files, is that correct?
Also any plans on adding MacOSX, that would really make it the perfect cross compiler.
Keith..
Re:Cross Compiling to Linux from Vista 17 years 1 month ago #111
  • Kjow
  • Kjow's Avatar
same problem here, but from Win7. I noticed that the problem is present in all linux targets (arm-linux cross-compiling too).
Other thing I noticed is that I can't cross-compile nothing from Linux: I installed CodeTyphon in Ubuntu 9.10, but in menu I haven't any choise.
A nice feature that will be great is to cross-compile a project in all targets (Windows, Linux, MacOSX, WinCE-arm, Linux-arm [maemo?;)]) we want in one click. (for example: a list of checkboxes with all targets).
Other nice thing is to use GLScene in arm platform (WinCE-arm and Linux-arm).
Thank you for great job. :)
Last edit: by Kjow.
Re:Cross Compiling to Linux from Vista 15 years 9 months ago #419
  • Delphi
  • Delphi's Avatar
I am having this problem in Windows XP. Can someone explain what is happening here?
I would appreciate it. I am trying out CodeTyphon for the first time.
Re:Cross Compiling to Linux from Vista 15 years 9 months ago #420
You must copy Unix libraries from target system
for all unix crossbuilds...
Compiler try to find these libraies to link
the libraries procedures/functions addresses in the executable...
LAB News for CodeTyphon 1.30 until now
-ADD pl_ExDesign (with object explorer)
-ADD pl_ExSystem
-ADD pl_freespider 1.2.3
-ADD pl_TitanScript
-ADD pl_Moon
-ADD pl_SynapseVS
-ADD pl_KambiEngine
-Update pl_Graphics32 (SVN 19-1-2011)
-Update pl_Synapse (SVN 04-2-2011)
-Update pl_PasDoc (SVN 21-1-2011)
-Update pl_GLScene (SVN 23-1-2011)
and many new samples to CodeOcean...
Re:Cross Compiling to Linux from Vista 15 years 9 months ago #421
We working on this Sir
LAB 1.30 version
has the new GLScene from SVN
but NO support for WinCE-arm
GLScene has some Assembly code only for Intel CPU not for ARM.
Someone must port this code...
Re:Cross Compiling to Linux from Vista 15 years 9 months ago #424
  • Delphi
  • Delphi's Avatar
Thank you so much for replying.
Not knowing which libraries to move from Linux, or where to place them, I decided to just install an .RPM Linux distro and see if I have much more luck installing a daily snapshot of Lazarus as the .deb packages are currently buggy ( mantis.freepascal.org/view.php?id=18656 ) and will not install Lazarus correctly on Ubuntu.
Again, Thank you.
Re:Cross Compiling to Linux from Vista 15 years 9 months ago #425
  • administrator
  • administrator's Avatar
Yes, this "LCLBase" package in SVN, has many many problems...
