CT on freeBSD 9 32 bit. 12 years 2 months ago #5816
  • fredvs
After lot of "wow" with installation and use of CT on freeBSD 10 64 bit, i have install the last version of freeBSD 32 bit (version 9)
But when try to install system files (option 0), i get error message, server does not find the 32 bit files requested by CT. (... does not exist).
Have you luck with freeBSD 9 32 bit and CT ?
Thanks.
Fred
Last edit: by fredvs.
CT on freeBSD 9 32 bit. 12 years 2 months ago #5842
  • fredvs
Re-Hello...
Hum, how to install system files in freeBSD 32 bit (option 0 in CT) ?
CT on freeBSD 9 32 bit. 12 years 2 months ago #5843
Sir, after CT installation, from CT setup.sh
cd /usr/lib/codetyphon
sh ./setup.sh
CT on freeBSD 9 32 bit. 12 years 2 months ago #5844
  • fredvs
sh ./setup.sh
=> Here console messages :=>
... => all extract ok !
Extracting help/zoom_search.js
Everything is Ok
Files: 568
Compressed: 14559412
CodeTyphon Studio 4.92 Setup for FreeBSD32
Settings: Platform=gtk2 Multiarch Mode=0
0) Install System Libraries
1) Run CodeTyphon Center (CTC)
11) -- Platform (widget) Setup
12) -- Multi-Architecture Setup
13) -- Build QT4Pas from Source
3) Remove FreePascal
4) Remove and Build FreePascal
5) Remove Typhon IDE
6) Remove and Build Typhon IDE
7) Remove ALL
8) Remove and Build ALL
9) EXIT
>>> Select an action (press 0..9 key): 0
Found: FreeBSD (OS ID:2000)
CodeTyphon OS Libraries Installation for
FreeBSD 9.x
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/xterm.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/xterm.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...lease/Latest/zip.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...lease/Latest/zip.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/unzip.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/unzip.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ease/Latest/wget.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ease/Latest/wget.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...lease/Latest/gcc.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...lease/Latest/gcc.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...lease/Latest/gdb.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...lease/Latest/gdb.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/.../Latest/binutils.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/.../Latest/binutils.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/gmake.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/gmake.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/iconv.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ase/Latest/iconv.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...t/xorg-libraries.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...t/xorg-libraries.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...se/Latest/libX11.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...se/Latest/libX11.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...e/Latest/libXtst.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...e/Latest/libXtst.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...xorg-fonts-type1.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...xorg-fonts-type1.tbz' by URL
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ration-fonts-ttf.tbz: File unavailable (e.g., file not found, no access)
pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/...ration-fonts-ttf.tbz' by URL
Install libraries for GTK2
/usr/local/sbin/pkg: Undefined symbol "_ThreadRuneLocale"
Finish !!!
CodeTyphon Try to Fix Links for SysLibraries
[INFO] Libraries Directory: /usr//local/lib
[ERROR] /usr/bin/qmake NOT Exists ???, can't make symlink for: qmake-qt4
[ERROR] /usr//local/lib/libc.so.6 NOT Exists ???, can't make symlink for: libc.so
[ERROR] /usr//local/lib/libdl.so.0 NOT Exists ???, can't make symlink for: libdl.so
[ERROR] /usr//local/lib/libpthread.so.6 NOT Exists ???, can't make symlink for: libpthread.so
[ OK ] /usr//local/lib/libX11.so Exists
[ OK ] /usr//local/lib/libgdk_pixbuf-2.0.so Exists
[ OK ] /usr//local/lib/libgtk-x11-2.0.so Exists
[ OK ] /usr//local/lib/libgdk-x11-2.0.so Exists
[ OK ] /usr//local/lib/libgobject-2.0.so Exists
[ OK ] /usr//local/lib/libglib-2.0.so Exists
[ OK ] /usr//local/lib/libgthread-2.0.so Exists
[ OK ] /usr//local/lib/libgmodule-2.0.so Exists
[ OK ] /usr//local/lib/libpango-1.0.so Exists
[ OK ] /usr//local/lib/libcairo.so Exists
[ OK ] /usr//local/lib/libatk-1.0.so Exists
[ OK ] /usr//local/lib/libXtst.so Exists
[ OK ] /usr//local/lib/libpangocairo-1.0.so Exists
[ OK ] /usr//local/lib/libGL.so Exists
[ OK ] /usr//local/lib/libGLU.so Exists
[ OK ] /usr//local/lib/libfreetype.so Exists
[ OK ] /usr//local/lib/libXxf86vm.so Exists
[ERROR] /usr//local/lib/libgtkglext-x11-1.0.so.0 NOT Exists ???, can't make symlink for: libgtkglext-x11-1.0.so
[ERROR] /usr//local/lib/libgdkglext-x11-1.0.so.0 NOT Exists ???, can't make symlink for: libgdkglext-x11-1.0.so
[ERROR] /usr//local/lib/libz.so.1 NOT Exists ???, can't make symlink for: libz.so
CodeTyphon Fix Links for SysLibraries
Finish !!!
7) Remove ALL
9) EXIT
CT on freeBSD 9 32 bit. 12 years 2 months ago #5845
Sorry Sir
THE problem is with FreeBSD packages (not ports)
if pkg_add FreeBSD 9.0 old package manager, don't know where is gcc ot gdb or xterm
then send email to FreeBSD.com or
try to install FreeBSD packages manual.
My suggestion is to use FreeBSD 10.x
We will test and FreeBSD 9.3-RELEASE at next days
CT on freeBSD 9 32 bit. 12 years 2 months ago #5846
  • fredvs
Many thanks...
Have tested FreeBSD 10.x, 64 bit, no problem, CT install perfectly.
But from FreeBSD > 9.1, only 64 bit version are available.
So, i you want a 32 bit version, you must use FreeBSD <= 9.1 !
It is strange, but the freeBSD team do not want to develop the 32 bit version anymore...
CT on freeBSD 9 32 bit. 12 years 2 months ago #5848
And this the reason for CodeTyphon MultiArch Lab Task link
We will test FreeBSD 9.3 and we will check MultiArch again.
In our lab FreeBSD64 10.x can run 32bit applications OS libraries Layers
but can't "compile or build", Programming Layer,
so no CT MultiAcrh for FreeBSD until now like Windows64, Solaris64, Fedora64 Linux, Mageia64 Linux, etc
MultiArch this a new Software technology on Linux, FreeBSD etc
We like FreeBSD, but the package manager (old and new) has problem and this is a fact,
we must wait FreeBSD guys to finish there tasks...
CT on freeBSD 9 32 bit. 12 years 3 weeks ago #6141
  • fredvs
Yep FreeBSD, finally, decides to not forget 32 bit ! =>
distrowatch.com/?newsid=08644
There is a 32 bit release available now :)
