[LAB] CodeTyphon on FreeBSD 10 12 years 7 months ago #5317
We test lab CodeTyphon ver 4.8 on
FreeBSD 10
with MATE Desktop
1)-Copy, Unzip and give full "sudo" permissions to current user
su
nano  /usr/local/etc/sudoers
add to last line in /usr/local/etc/sudoers file
USER	ALL=(ALL) NOPASSWD: ALL
Defaults: USER timestamp_timeout=-1
2)-Install CodeTyphon
3)-Install "System Libraries" from CT installation script
4)-Build CodeTyphon (GTK2)
The following user(s) said Thank You: Miquel Matas, fredvs
[LAB] CodeTyphon on FreeBSD 10 12 years 7 months ago #5318
General Tests list for GTK2 (MATE) platform:
-CT Installation
-CT Build All procedure
-CT Update procedure
-FreePascal compiler tests
-Typhon IDE tools tests
-CodeOcean samples tests
pl_BGRAbitmap and pl_BGRAueControls,
pl_Graphics32,
pl_VirtualTrees,
pl_ColorLib,
pl_ExControls,
pl_Opengl,
pl_PascalSCADA,
pl_GlassDocking,
some tools and the new "Update/Download lab CT version" functionality..
The following user(s) said Thank You: Miquel Matas, fredvs, kenlee
[LAB] CodeTyphon on FreeBSD 10 12 years 3 months ago #5750
  • fredvs
  • fredvs's Avatar
Is it possible to install CT on freeBSD with only Xorg installed ?
I have try witht the install.sh, but that script use "sudo" who is a Linux command.
If Linux-compatibility is needed, how to install Mate on freeBSD ?
Many thanks.
[LAB] CodeTyphon on FreeBSD 10 12 years 3 months ago #5751
sudo is NOT only linux program CT use sudo on Linux, FreeBSD and Solaris OSes.
Now take a cup off anything you want :) ... to start
[A] Install FreeBSD 10 to your PC or VM.
-1) Download FreeBSD-10.0-RELEASE-i386-dvd1.iso or FreeBSD-10.0-RELEASE-amd64-dvd1.iso from FreeBSD Download page info
-2) Start FB installation but
----i ) On VM select to install end "Kernel Sources"
----ii) Add new "normal user" at installation procedure
[ B] Install MATE Desktop on FreeBSD 10
The new installed FreeBSD it's only "Terminal OS" so...
-1) Boot in to your new OS as "root" user.
-2) Open a terminal and execute: portsnap fetch extract update => to update and install FB Ports, (30 minutes) this is a log time process ....
-3) Execute pkg install nano => to install nano, answer "Yes" to any question (2 minutes)
-4) Execute pkg install sudo => to install sudo, answer "Yes" to any question (2 minutes)
-5) Execute pkg install xorg => to install xorg, answer "Yes" to any question (15 minutes)
-6) Execute pkg install gnome2 =>to install gnome2, answer "Yes" to any question (15 minutes)
-7) Execute pkg install gdm => to install GNOME2 Display Manager, answer "Yes" to any question (15 minutes)
-8) Execute pkg install mate => to install MATE Desktop, answer "Yes" to any question (15 minutes)
-9) Execute reboot => to Re-Boot your new OS
[C] Config your new OS FreeBSD 10
-1) Boot again as "root" user.
-2) Execute nano /etc/rc.conf and add to your FreeBSD configuration file (this is NOT Linux :whistle: )
dbus_enable=”YES”
hald_enable=”YES”
mouse_enable=”YES”
gnome_enable=”YES”
gdm_enable=”YES”
-3) Execute Ctrl+x to exit from nano and choose save (y/Y).
-4) Execute reboot => to Re-Boot your new OS
Now your FB box must open with gdm (GNOME2 Display Manager)
-4) Select MATE desktop
-5) Boot as "normal" user
[D] Install CT on FreeBSD 10
same as Linux...
-1) Download CT
-2) Extract zip file
-3) Execute su
-4) Execute nano /usr/local/etc/sudoers => to edit sudo configuration file
-5) Add at last line:
username	ALL=(ALL) NOPASSWD: ALL
Defaults: username timestamp_timeout=-1
-6) Execute: Ctrl+x to exit from nano, choose save (y/Y) and close the "root terminal"
-7) Open a new terminal
-8) Execute cd CodeTyphonIns
-9) Execute sh ./install.sh and select 0 to install CT
Finally on CT Setup:
i ) Select 0 to install System Libraries and
ii) Select 8 to Build ALL
and have fun...
The following user(s) said Thank You: fredvs
[LAB] CodeTyphon on FreeBSD 10 12 years 3 months ago #5752
  • fredvs
  • fredvs's Avatar
Yep, Sternas => Wow, many thanks for that clear explanation.
Everything goes ok till -6) Execute pkg install gnome2 => "gnome2 not found in repository...".
I decided then to try with pc-bsd and... everything goes easy and perfect...
Pc-bsd gives you the choice to install this desktops (and all is included in
package !):
- FluxBox
- Awesome
- Cinnamon
- FVWM
- Gnome3
- i3
- IceWN
- KDE4
- Lumina
- LXDE
- Mate
- OpenBox
- Ratpoison
- spectrwm
- WindowLab
- Window Maker
- XFCE4
The install was ok (but very loooong) and what super-good is that it recognize
that VirtualBox is used and install Guest additions too (no need of
connection, all is included in pc-bsd.iso)
After that, CT install => cd codetypnon => su => bash ./install.sh
Wow, Sternas, what a perfect job you have done, all is working with the right bsd-commands, all is installed ok (only problem for installing qt4pas library).
I will do some test and write you later.
Many, many, many thanks Sternas.
Fred
Last edit: by fredvs.
[LAB] CodeTyphon on FreeBSD 10 12 years 3 months ago #5753
Thanks and have fun Sir in FreeBSD Galaxy...
[LAB] CodeTyphon on FreeBSD 10 12 years 3 months ago #5754
Oh, on PC-BSD to config sudo :
-4) Execute nano /usr/local/etc/sudoers.d/sudoers => to make an "empty continue" sudo configuration file
-5) Add :
[LAB] CodeTyphon on FreeBSD 10 12 years 3 months ago #5756
  • fredvs
  • fredvs's Avatar
Super, all working like charm. ;)
Hum, very litle detail, when i run install.sh script, after su command, CT script gives a warning about root-user that is not the right way to do.
But without su command, script does not run...
Maybe you could hide that warning message for freeBSD, (or i missed something) because if i run it after su, the installation was perfect and i get a "Big IDE compiled OK" much faster than with Linux. ;)
I do not have try cross-compile yet, but till now, no problem, all is perfect.
Many thanks Sternas and big Wow.
