Components and Libraries for Graphics 3D Development, discussions, problems and suggestions
Direct3D demos problem 13 years 4 weeks ago #4543
  • myname
  • myname's Avatar Topic Author
hi
am using winxp , all direct3d demos (with DXUT) dosen't work , without error message , just a black window that disappeared immediately after execusion . in windows7 all the demos works ok !
BTW : with delphi they work in both winxp and win7.
can some one figure out where is the problem ?
thanks
Direct3D demos problem 12 years 9 months ago #5068
  • kuzibri
  • kuzibri's Avatar
Direct3D demos problem: Probably cause WinXP with DXUT is not supported anymore and Win7 does. Do not know why it's working with Delphi on both platforms.
kindest regards, Kuzibri
Life is finite but learning never ends. You can only get better by hope and the support of your family and dear friends!
Artemis V73 NLD; Radio 2.15; SPL 3.03
Last edit: by kuzibri.
