pl_ASIOVST 8 years 8 months ago #11292
  • Peter Schneider
  • Peter Schneider's Avatar Topic Author
please change from line 130 in unit allAsioVSTRegisterIDE.pas :
    + 'begin' + le
    + '  Application.Initialize;' + le
    + 'end.';
because it's a library (dll), not an application.
pl_ASIOVST 8 years 8 months ago #11293
we put your suggestion code in to LAB CT for test
pl_ASIOVST 8 years 8 months ago #11294
  • Peter Schneider
Thanks !
Here is a demo application.
Might be placed in subfolder "samples".
Can be tested with "VST Plugin Analyser.exe", Audacity,
Audiodope, Samplitude or any other audio software ..
Peter
Last edit: by Peter Schneider.
pl_ASIOVST 8 years 8 months ago #11296
... :woohoo: ...
thanks...
pl_ASIOVST 8 years 8 months ago #11312
  • Peter Schneider
Here is another demo project.
Might also be placed in subfolder "samples".
Peter
PS: project in pl_ASIOVST sub-subfolder ztest doesn't work, so might be deleted.
pl_ASIOVST 8 years 8 months ago #11314
we add and this sample to CodeOcean
Yes, all "ztest" project are LAB test
pl_ASIOVST 8 years 8 months ago #11315
  • Peter Schneider
Thank You !
Now here's number three.
Also from old ASIOVST1.0
and edited to work with pl_ASIOVST.
Cheers, Peter
pl_ASIOVST 8 years 8 months ago #11319
  • Peter Schneider
this plugin originally was "NoGUIFilter".
I added a GUI today, makes more sense in my eyes.
Cheers,
Peter
pl_ASIOVST 8 years 8 months ago #11320
pl_ASIOVST 8 years 8 months ago #11325
  • Peter Schneider
next plugin is a "synth".
Works now (tested inside Audiodope.exe), but ... I cannot solve
VoiceList.pas(119,29) Warning: Use of +offset(%ebp) for parameters invalid here
because I don't know the FPC's assembler synthax.
Maybe You have an idea of how to fix this .. ?
VoiceList.pas code :
  function ReturnAddr: Pointer;
  asm
          MOV     EAX,[EBP+4]
Cheers, Peter
pl_ASIOVST 8 years 8 months ago #11326
  • Peter Schneider
I had to edit the object's function names in "VUMeterModule.pas" in TestPlugin02".
They have to match the function template names .. Please see appended ZIP file.
Cheers,
Peter
pl_ASIOVST 8 years 8 months ago #11342
  • Peter Schneider
In "allAsioVSTRegister.pas" line 42 missing:
DAV_GuiLevelMeter,
In "allAsioVSTRegister.pas" line 102 missing:
TGuiLevelMeter,
pl_ASIOVST 8 years 8 months ago #11343
  • Peter Schneider
With these changes in the previous post, the appended Plugin Example compiles and runs.
"Wavedisplay"
pl_ASIOVST 8 years 8 months ago #11344
we add "TGuiLevelMeter" to Registration of the package
for asm problem in TestPlugin05=>VoiceList.pas
use this code
class procedure TVoiceList.Error(const Msg: string; Data: Integer);
  raise EListError.CreateFmt(Msg, [Data]);
If you want, we can upload new CodeTyphon Lab version
with the latest sources
pl_ASIOVST 8 years 8 months ago #11345
  • Peter Schneider
Sternas Stefanos wrote: If you want, we can upload new CodeTyphon Lab version
Thanks for Your help !
This in general would be a good idea. Before doing so You need to
convert all the TestPluginXX projects to the CodeTyphon synthax (*.ppr ?)
I didn't start off with CodeTyphon because some weeks ago I didn't even know it exists.
A friend of mine converted the pl_ASIOVST for me so I was able to start working on it, under Lazarus.
If You upload new CodeTyphon Lab version I would continue my work under CodeTyphon.
There are still some TestPlugins left to convert from ASIOVST 1.3 ... ;-)
Please let me know !
pl_ASIOVST 8 years 8 months ago #11349
Give us 1-2 days for some final tests
and we will upload LAB CodeTyphon 6.40 revision 006340
Here is the history and the forum topic for LAB CodeTyphon 6.40
pl_ASIOVST 8 years 8 months ago #11365
  • Peter Schneider
Yesterday I had time to download LAB CT 6.40 Revision 006340 BETA 1
I was able to compile and run one of the TestPlugins. :)
It would be helpful if the "VST Plugin Analyser.exe" would be in the target directory "xbin" under pl_ASIOVST.
"VST Plugin Analyser.exe" can be found in the original "DelphiASIOVST-v1.3.zip" archive at
sourceforge.net/projects/delphiasiovst/?source=typ_redirect
in directory "bin"
pl_ASIOVST 8 years 8 months ago #11366
we will check your suggestion
pl_ASIOVST 8 years 8 months ago #11367
  • Peter Schneider
I translated the next ~ 9 plugins, unfortunately 6 of them do not work, in different ways.
So I add the the three ones that do compile and run.
Please apologize, they're still Lazarus projects.
I have to learn how to convert them to CodeTyphon.
1 - "Delayla" - Simple Delay
pl_ASIOVST 8 years 8 months ago #11368
  • Peter Schneider
2 - "SimpleSampler"
