Mandriva scrip fix 13 years 9 months ago #2641
  • Aleksandar
  • Thank you received: 31
I found two bugs in "ln1_Install_SysLibraries_For_Mandriva.sh" script.
First of all, I am not sure where you get this qt4-qmake package?! libqt4-devel will install qmake command.
sudo urpmi libxtst-dev on 64bit system will install i586 package instead of x86_64 one. It might work if you do not have 32bit repos enabled, but I am not sure about that.
On 32bit system it will work just fine.
Proper package name that will install x86_64 package on 64bit system (and i586 package on 32bit system) is libxtst-devel.
Please fix that.
I would also suggest you to include this version which is much smaller and cleaner than your current version.
Please let me know if you find any problem.
#               CodeTyphon Project
#      Copyright (c) PilotLogic Software House.
#               All rights reserved.
#        This Script Install to Mandriva Linux
#      base libraries to Build and Run CodeTyphon
echo "----------------------------------------------------"
echo " CodeTyphon OS Libraries Installation for"
echo "              Mandriva Linux"
echo "."
ciplatiform=$1
# automaticly update Mandriva
sudo urpmi --auto-update --auto
# install needed libraries
sudo urpmi --auto gcc-c++ xterm gdb gpm
sudo urpmi --auto gtkglext-devel
sudo urpmi --auto mesa-common-devel
sudo urpmi --auto libxtst-devel
# Install libraries for QT
if [ $ciplatiform = 1 ] ;
then
    echo "."
    echo "Install libraries for QT"
    echo "."
    sudo urpmi --auto libqt4-devel
    sudo urpmi --auto libQt4Pas5
fi
echo "CodeTyphon OS Libraries Installation"
echo "Finish !!!"
sleep 5
This script is clean of my "32bit on x64 system tricks". :)
Mandriva scrip fix 13 years 8 months ago #2671
  • Thank you received: 1138
we put your updates
Mandriva scrip fix 13 years 2 days ago #4261
  • Aleksandar
sternas wrote: Thanks Sir
we put your updates
In CT 4.41 I still see same old Mandriva script as it was then. :huh:
Mandriva scrip fix 12 years 7 months ago #4780
  • Aleksandar
we put your updates
For some reason CodeTyphon 4.6 still have old buggy install script for Mandriva and it's derivatives.
Please fix this.
