Install problems 15 years 6 months ago #498
  • tkamphuis
  • tkamphuis's Avatar Topic Author
It is not possible for me to install CodeTyphon Lazarus anymore.:(
In the past installing was OK, but now I i'm not able to install.
I removed the pp, Lazarus en CodeTyphon directories on the C: drive.
Via CodeTyphon Center I install free Pascal (Clean, Extract Source and Build Compile)
Afterwards I install Lazarus (Lazarus clean, Extract source, Lazarus 32Bit build BigIDE)
No success.
I tried on a different PC, also no success.
Hereby the script outputs for PP and Lazarus.
File Name: FreePascalScript.txt
File Size:318 KB
File Name: Lazarusext...urce.txt
File Size:622 KB
File Name: Lazarusbuild.txt
File Size:306 KB
Please help.
Last edit: by tkamphuis.
Re: Install problems 15 years 6 months ago #499
-Did you remove preview ver of FreePascal and Lazarus? (NOT Codetyphon Edition)
-Did you run CodeTyphon as Administrator?
-Dir you try Setup.bat (option 7)?
-Please Run from Codetyphon Center=>CodeTyphon=>'Remove and Build ALL (FPC+Lazarus BigIDE)' command
Re: Install problems 15 years 6 months ago #501
  • tkamphuis
I Did remove previous ver of FreePascal and Lazarus
I Did run CodeTyphon as Administrator?
I Did run Setup.bat (option 7)?
I did run from Codetyphon Center=>CodeTyphon=>'Remove and Build ALL (FPC+Lazarus BigIDE)' command
I even removed all references in the Windows registery to Free Pascal and Lazerus.
I have also installed Delphi RAD Studiao 2010 (could that be a problem?)
On a different clean PC the same problem.
But still no luck in installation:
-- Last part of the install script output
Install Script output.txt
Compile Lazarus Win32
C:/pp/bin/i386-win32/make.exe -C packager/registration all
make.exe[1]: Entering directory `c:/lazarus/packager/registration'
C:/pp/bin/i386-Win32/rm.exe -f ../units/i386-win32/lazaruspackageintf.ppu
C:/pp/bin/i386-Win32/gmkdir.exe -p ../units/i386-win32
C:/pp/bin/i386-Win32/ppc386.exe -gl -Fu. -Fuc:/pp/rtl -FE. -FU../units/i386-win32 -di386 lazaruspackageintf.pas
Free Pascal Compiler version 2.5.1 [2011/02/24] for i386
Copyright (c) 1993-2010 by Florian Klaempfl
Target OS: Win32 for i386
Compiling lazaruspackageintf.pas
Fatal: Can't find unit system used by LazarusPackageIntf
Fatal: Compilation aborted
make.exe[1]: *** [lazaruspackageintf.ppu] Error 1
make.exe[1]: Leaving directory `c:/lazarus/packager/registration'
C:\pp\bin\i386-win32\make.exe: *** [packager/registration] Error 2
INFO: create c:\lazarusTemp directory
Strip Lazarus
INFO: Lazarus.exe NOT EXIST !!!
C:\pp\bin\i386-win32\Strip: 'C:\lazarus\lazarus.exe': No such file
C:\pp\bin\i386-win32\Strip: 'C:\lazarus\startlazarus.exe': No such file
C:\pp\bin\i386-win32\Strip: 'C:\lazarus\lazbuild.exe': No such file
C:\pp\bin\i386-win32\Strip: 'C:\lazarus\tools\svn2revisioninc.exe': No such file
INFO: Lazarus for win32 Striped OK
Lazarus32 Save -User- Settings for Windows
C:\lazarus\bin32\settings\compilertest.pas
C:\lazarus\bin32\settings\editoroptions.xml
C:\lazarus\bin32\settings\environmentoptions.xml
C:\lazarus\bin32\settings\inputhistory.xml
C:\lazarus\bin32\settings\lazarus.dci
C:\lazarus\bin32\settings\miscellaneousoptions.xml
C:\lazarus\bin32\settings\packagefiles.xml
C:\lazarus\bin32\settings\staticpackages.inc
8 bestand(en) gekopieerd
Copy Laz32 Executables to User Settings
Het systeem kan het opgegeven bestand niet vinden.
ERROR: Lazarus32 IDE NOT Build
INFO: Sorry, Your Operating System NOT support 64Bits
can NOT build Lazarus for x86_64-win64
Terminate Action at 27-2-2011 15:06:37
ExitCode : 0
Re: Install problems 15 years 6 months ago #502
We will check this Sir
Your windows version ?
Re: Install problems 15 years 6 months ago #503
  • tkamphuis
Window XP SP3
Thank you for checking.
Re: Install problems 15 years 6 months ago #504
Win XP Dutch ?
Re: Install problems 15 years 6 months ago #506
  • tkamphuis
Yes Win XP Dutch, but in the past that was no problem for CodeTyphon.
Script.txt
Re: Install problems 15 years 6 months ago #538
  • Gintas
  • Gintas's Avatar
  • Graphics Designer/Developer
I don't think the problem is with Windows version. I have English WinXP Home 32bit SP3.
There is a problem with "fpc.cfg" since FPC can find "system" unit.
Sure specifying the right source paths doesn't helps.
I have problem with components:
Free Pascal Compiler version 2.4.3 [2011/03/01] for i386
Compiling pl_zeosdbocomp.pas
Compiling .\source\component\ZComponentReg.pas
Compiling .\source\component\ZPropertyEditor.pas
Compiling .\source\core\ZClasses.pas
ZClasses.pas(93,38) Fatal: Syntax error, ":" expected but "identifier IID" found
make.exe[2]: *** [pl_zeosdbocomp.ppu] Error 1
make.exe[2]: Leaving directory `c:/lazarus/components/pl_ZeosDBO'
make.exe[1]: *** [bigidecomponents] Error 2
make.exe[1]: Leaving directory `c:/lazarus/components'
C:\pp\bin\i386-win32\make.exe: *** [bigidecomponents] Error 2
Yep,I used own FPC 2.4.3 specified in a system PATH variable.
Will try to use the default one provided with CodeTyphon .
Edit:
Okies. Now added the freshly compiled FPC 2.5.1 from CodeTyphon path into PATH environmental variables.
This time I am getting problems with GLScene package:
Compiling .\source\GLFPSMovement.pas
Compiling .\source\GLNavigator.pas
Compiling .\source\GLScreen.pas
GLScreen.pas(180,62) Hint: Local variable "DeviceMode" does not seem to be initialized
GLScreen.pas(251,23) Hint: Local variable "deviceMode" does not seem to be initialized
GLNavigator.pas(360,47) Hint: Local variable "D" does not seem to be initialized
GLNavigator.pas(394,21) Hint: Local variable "Vector" does not seem to be initialized
GLNavigator.pas(400,16) Hint: Local variable "B" does not seem to be initialized
GLNavigator.pas(404,16) Hint: Local variable "S" does not seem to be initialized
GLNavigator.pas(472,19) Error: Identifier not found "GLShowCursor"
GLNavigator.pas(480,19) Error: Identifier not found "GLShowCursor"
GLNavigator.pas(486,33) Error: Identifier not found "GLGetScreenWidth"
GLNavigator.pas(487,34) Error: Identifier not found "GLGetScreenHeight"
GLNavigator.pas(490,18) Error: Identifier not found "GLSetCursorPos"
GLNavigator.pas(506,20) Error: Identifier not found "GLGetCursorPos"
GLNavigator.pas(532,21) Error: Identifier not found "GLSetCursorPos"
GLNavigator.pas(540,32) Error: Identifier not found "GLGetScreenWidth"
GLNavigator.pas(541,33) Error: Identifier not found "GLGetScreenHeight"
GLNavigator.pas(579) Fatal: There were 9 errors compiling module, stopping
:sick:
Now this really sucks :)
Last edit: by Gintas.
Re: Install problems 15 years 6 months ago #539
From FPC 2.4.3 to 2.5.1 some things changed ...
Remove all from C: driver and old FPC-Lazarus installations
and "build all" from CodeTyphon Center
Re: Install problems 15 years 6 months ago #543
  • tkamphuis
Ok. I did some other test. I installed CodeTyphon Lazarus on Windows 7 32 bits (dutch) in a VirtualBox environment and everything is ok. After that I copied the Lazarus and pp directory to WindowsXP and voila all is ok. So I think compiling Lazarus or Free Pascal in Windows XP behaves different as in Windows 7.
I will try the same test by installing CodeTyphon Lazarus In a VirtualBox for Windows XP to check.
So standby for the results.
Re: Install problems 15 years 6 months ago #544
We test every CodeTyphon release in
Win7-32, Win7-64, Ubuntu 10.10-32 and Ubuntu 10.10-64
I test ver 1.4 in VirualBox WinXP En and all is OK
Please if you find something for this problem post/share we us...
The following user(s) said Thank You: Gintas
Re: Install problems 15 years 6 months ago #545
  • Gintas
  • Gintas's Avatar
:cheer:
Finally solved the problem and got IDE running :)
There is lots of neat extra components and I will need to check out their licences.
The problem was that I was using D:\ partition. I needed to copy CodeTyphon folder
to Windows installation disk - C:\ . That was the problem. :)
Re: Install problems 14 years 10 months ago #1368
  • tkamphuis
Installing the new version 2.30 is very easy. No problems any more.
Re: Install problems 14 years 10 months ago #1369
Thanks Sir, for your report
We want more users report/suggestions
Re: Install problems 14 years 10 months ago #1370
  • 4aiman's Avatar
ubuntu 10.10.
Build Big Ide - ok!
but then...
I've removed all fpc and lazarus before installation. I Did install system libraries.
And I've fount some fpc.cfg in /etc.
Where I'm supposed to put it to?
regards!
Last edit: by 4aiman.
Re: Install problems 14 years 10 months ago #1371
Method1
Please go to your /etc/ directory end delete fpc.cfg is from Old Freepascal installation
copy CodeTyphon fpc.cfg to your /etc (/user/lib/codetyphon/bin/binfpc/i386-linux
and give to you (username) Linux permissions to read this new file /etc/fpc.cfg
sudo rm -f /etc/fpc.cfg
sudo cp -f /user/lib/codetyphon/bin/binfpc/i386-linux/fpc.cfg /etc/
sudo chmod 644 /etc/fpc.cfg
But this is automatic procedure from CodeTyphon ...so
Method2
try to remove /etc/fpc.cfg ( sudo rm -f /etc/fpc.cfg )
and run from CTC "remove and build ALL"
Re: Install problems 14 years 10 months ago #1372
  • Rain
  • Rain's Avatar
CT 2.30 installs flawlessy on Win XP.
Only the file associations are not adjusted to the new locations.
.lpr, .lpi, .pas, .pp point to the old locations. This can be corrected manually, so it's no problem.
Also Remove and Build ALL does not remove CT 2.20 installations c:\lazarus and c:\pp remain untouched. It just adds the c:\codetyphon directory with content.
But this doesn't affect functionality.
The new CT 2.30 runs fine.
Re: Install problems 14 years 10 months ago #1373
  • 4aiman's Avatar
rain wrote: Also Remove and Build ALL does not remove CT 2.20 installations...
It never did. Every time you should either cleanup using old CTC or remove old files manually.
Haven't you read some other messages about installation problems? Every time sternas asks whether you run cleanup or not. Even if new CT removes smth that belong to old one - no one ever said it should.
And on top of that, sometimes uninstalling old CT with new CTC ends in loss of opportunity to install ANY version of CT. If someone want deny this - just install CT 1.6 (yes, even now I'm using ver 1.6 CT, as it proved itself as stable one, where glscene runs fine, and there's no some errors like "it need to be implemented" although 1.6 already did the same thing, and so on and so forth) and then use "remove and build all" option from CT 2.2 installator or CTC menu. After this xp sp3 pro cannot build neither big nor small ide. And cleanup "by hands" is a long and confusing procedure.
Let sternas correct me if I'm wrong, but I've some code samples which compiles in 1.6. and refuse to compile in any of the later CT. And I've wrote it here, but got no response. And tomorrow I'll try to change old fpc.cfg with new one (although i Did cleanup, and just can't understand why there's old file, and why it's not overwritten automatically during installation if it shares the same place with old one...)
If anyone interested in my samples that lead lazarus to crash - tell me, cause just posting isn't enough, but i'm afraid my samples will be ignored as some of my messages... and... well, it's not about CT, but any attachment is GONE after submitting a post.
I'm not trying to MAKE someone to do smth, I just want to help, as I really want new, better version of what I'm already have... But, please, if you has smth important to do (like new ct 2.3) let us all know, that our problems are intended to be solved soon, as new ver is comming out soon... Else it's makes me (personally) feel like there's no point in feedback, as there's no reaction.
Regards!
Re: Install problems 14 years 10 months ago #1374
CT version 2.30 is the best until now
and GLScene run ok to all CT Host Layers
We make the new CT 2.30 directory structure:
-for better installation
-to solve makefiles problems
-to prepare CT for next Generation Plan with Rolling installation...
etc
CT is dynamic project and we try to make it better.
For sample, at lab version
1)We add to pl_win_directx pkg, support for DirectX 10/11 and
this action request some CT code changes...
2)And the new (experimental) pl_Lava pkg request some CT code changes...
Please Sir,
my suggestion is to remove old installation files (I can post a script file after your request)
and try to install new CT ver 2.30
oh, a screen from pl_Lava pkg on Debian Linux 6.0.3 64 bit...
Re: Install problems 14 years 10 months ago #1376
  • 4aiman's Avatar
Here's what I've done:
- run ctc 1.6
- "IDE settings clear"
- "remove lazarus from disk"
- "clean lazarus"
- "remove FPC from disk"
- "clean FPC"
- check for any remaining folders on disc C. None was found (there was no "pp", "lazarus", "lazarus temp", "codetyphon")
Warning: Spoiler!
- unzip to C: ct v2.3
- run ct 2.3
- "FPC extract source"
- "FPC 32bit build compiler"
- "lazarus extract source"
- "lazarus 32bit build big ide"
And here's what I've got: 4aiman.ucoz.ru/warehouse/log.7z
And as for examle I told earlier...
Here is project with some tab controls and glsceneviewer (only 87.6 Kb). When opened under ubuntu 10.10, Lazarus would crash. Could you check that, please?
