Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 3 weeks ago #7604
  • Fernando Pasqueto
  • Fernando Pasqueto's Avatar Topic Author
Good day.
I'm three days trying to install code typhon 530 I believe that is the latest available stable version, my installation environment and ubuntu 14:04 64-bit on a real machine is not virtualization,
I did the installation as indicated by the link Sternas www.pilotlogic.com/sitejoom/index.php/fo...u-14-04?limitstart=0 however not got successes am attaching the error log generated in an attempt to create a BIG IDE, if someone can help me since I thank very ja
Last edit: by Fernando Pasqueto.
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 3 weeks ago #7605
  • Thank you received: 1138
at line 26540
/usr/bin/ld: cannot find -lGL
Please, install libGL library to your PC
Did you install System Libraries ?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 3 weeks ago #7608
  • Fernando Pasqueto
only the installer libs
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 3 weeks ago #7609
  • Fernando Pasqueto
which package name should I look for
qmake-qt5, libgl.so, libgl.so.1, libgtkglex-x11-1.0.so, libgdkglext-x11-1.0.so
I think I need to install these packages on my ubuntu in system libraries status are with defect
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 3 weeks ago #7617
  • Fernando Pasqueto
which more simple Linux distribution for installation of code typhon?
maybe the problem is to be using 64-bit system?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7623
First page of our web page
has many Linux to use
why don't use Ubuntu 15.04 64 bits with Mate desktop ?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7624
  • fredvs
  • fredvs's Avatar
Why don'use Mint, a branch of Ubuntu (with all the good and without the less good) that use Mate desktop ?
=> linuxmint.com/
PS: Look at statistics of DistroWatch (right side of page) => distrowatch.com/
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7625
My suggestions:
Fedora 22 for MultiArch and we install All possible Desktops
Debian 8 NO MultiArch but we install All possible Desktops
Linux Mint with MATE
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7626
  • fredvs
  • fredvs's Avatar
My suggestions:
Agree :)
Hum, do you know that Mint is perfectly working in MultiArch ?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7627
  • Fernando Pasqueto
like using lts versions, can be ubuntu 14:04 mate?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7628
  • Fernando Pasqueto
Ubuntu 14.04 does not work Multiarch?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7629
  • fredvs
  • fredvs's Avatar
Personally, i was not able to to do it work.
Also, loooot of problems with the "revolutionary" Unity project.
You will not be able to do TTrayIcon work (or with lot of work).
Last edit: by fredvs.
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7630
  • Fernando Pasqueto
install desktop mate in ubuntu, must install typhon not put any installed libs as posted in some pictures someone could help me solve these dependencies?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7631
Just go to CodeTyphon Center
-Set Settings => Platform to GTK2
-Host PC => install System Libraries
@fredvs And or us, Unity is NOT for Desktop PC
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7632
  • Fernando Pasqueto
I like that, I tested with qt and gtk, however some libs simply will not install as shown in the pictures.
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7633
  • fredvs
  • fredvs's Avatar
I was talking about this Unity => unity.ubuntu.com/
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7635
@fredvs ++1 and I was talking for the same Desktop
@fpasqueto no problem with this
try to build BigIDE
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7636
  • Fernando Pasqueto
++1?
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7640
  • Fernando Pasqueto
Sternas look errors installing the library as indicated by you.
File Name: log_instal..._lib.txt
File Size:23 KB
Problem installing Code Typhon 530 in Ubuntu 14.04 11 years 2 weeks ago #7641
the 32 bits Layer has problem,
because CT don't support MultiArch on Debian/Ubuntu info yet
Debian/Ubuntu OS Structure is NOT the same with Fedora or Mageia MultiArch OS Structure
64 bits layer is OK
