Screen resolution issue under VirtualBox & WinXP 9 years 11 months ago #7326
  • Gary Campbell
  • Gary Campbell's Avatar Topic Author
Hi all,
I have CodeTyphon running on my regular Windows XP computer and it runs fine. I also have CodeTyphon running on Ubuntu 14.04 and it works fine there too.
However, I also have VirtualBox runnning on my Ubuntu computer with WindowsXP running under VirtualBox. CodeTyphon loads, but when I try to run Typhon32, the WindowsXP screen resolution changes, and Typhon hangs in memory. Attached is a screen shot of the screen when I try to load Typhon.
This is not an urgent matter, but I was wondering why this is happening, since I read that Typhon works under VirtualBox. My screen resolution is set at 1280 x 1084.
Last edit: by Gary Campbell. Reason: typo
Screen resolution issue under VirtualBox & WinXP 9 years 11 months ago #7327
  • Thank you received: 1121
did you install System libraries ? info
Your VM has True Color ?
Screen resolution issue under VirtualBox & WinXP 9 years 11 months ago #7334
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
Hi gcampbel,
it looks like a "driver" crash.
Did you install the guest additions in your XP VM ?
Be aware that to add some support for 3D you will have to do it in XP safe mode.
+ of course DirectX libraries
Another thing you could try if it is still not working is to reset your parameters of Typhon (in CodeTyphon Menu, Typhon-IDE, IDE Settings - Clean)
Hoping this will help you :)
Screen resolution issue under VirtualBox & WinXP 9 years 3 months ago #8822
  • Gary Campbell
Everything is working fine under VirtualBox running WindowsXP. Thank you all.
