CodeTyphon 4.10 GEN IV 13 years 7 months ago #3501
We will try Sir
can you help us ?
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3502
  • Juanjo
  • Juanjo's Avatar
sternas wrote: We will try Sir
can you help us ?
Hi sternas:
Here is my post to Lazarus Forum and some reponses.
forum.lazarus.freepascal.org/index.php/t...16713.html#msg116713
I do not know for the moment if the version of Lazarus you are using is more old or is the latest such as the moderator marcov describes.
Such as i wrote here www.pilotlogic.com/sitejoom/index.php/fo...5connection-where-is there is no way to compile the unit to activate the MYSQL55 Component.
For some reason the flag is disabled.
{$IF FPC_FULLVERSION>= 20601}
{.$DEFINE HASMYSQL55CONNECTION}
{$ENDIF}
Which is the reason??
Other moderator of Lazarus forum says:
It is in trunk since May 2012 and certainly
It's very strange that CodeTyphon has not enabled these components.
you know ???
Last edit: by Juanjo.
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3503
I think Lazarus people speak theoretical only Sir.
We don't know any Lazarus release with FPC 2.7.1 and MYSQL55 component,
do you?
building is not the same as releasing it...
Anyway, until now the problem was FPC makefiles.
We will try to re-write these makefiles and test again.
and a screen from our tests...
The following user(s) said Thank You: Juanjo
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3504
and the final screen from our tests (rewrite-build db FPC makefiles).
ALL FPC 2.7.1 SVN Rev 23849 (15-03-2013) good things...
Now we must test
Win64, Linux32, Linux64, FreeBSD32, FreeBSD64, Solaris32 and Solaris64
for next CodeTyphon release, it's not so simple...
The following user(s) said Thank You: FredyCC, Juanjo
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3509
  • Juanjo
  • Juanjo's Avatar
Hello:
Thank you very much Sir. It's what I missed for some time.
sternas wrote: We don't know any Lazarus release with FPC 2.7.1 and MYSQL55 component,
do you?
Yes, :) but the information about versions is what i have. I'm using Linux Mint Debian x64 and about box of Lazarus PilotLogic Distribution 4.10 :) displays ........
Lazarus #:1.1 (version)
FPC 2.7.1 (version)
SVN 40461 CT (distribution)
And from the shell:
~ fpc -iV
2.7.1
Thank you very much Sir. :)
I wait impatiently the next release.
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3510
We finish all db tests
and a screen from OpenIndiana64 (Solaris64)...
Don't forget, we use CodeTyphon for Commercial Oracle Database 11g projects
so we programming with CT on Solaris 11.1 Server native...
oh, it's Not Lazarus it's "Lazarus MAX"... :)
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3511
  • ExDatis
  • ExDatis's Avatar
Hi there!
It works perfectly on openSUSE 12.3(new release, 2 days old) :lol:
Thanks again for new generation of CT!
Last edit: by ExDatis.
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3512
Yes, OpenSuse 12.3 is in our lab
for tests it's a BIG OS.
Soon firsts screens
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3514
  • fredvs
  • fredvs's Avatar
Have you test CodeTyphon 4.10 with Ubuntu 13.04 64 bits ?
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3515
No yet Sir
I think tomorrow will be possible
CodeTyphon 4.10 GEN IV 13 years 7 months ago #3589
  • Olver Moreno
  • Olver Moreno's Avatar
dibo wrote: I still can't build cross elements for Win32/64 on linux host. Last version which worked fine was 3.90
My configuration:
Linux Mint 14 64bit, XFCE edition
1. After clear install CT 4.10. In CT Studio -> Cross Build -> Free Pascal 64bit I don't have any WinXX elements
2. So I run Cross Build -> Toolchains builder
3. In list "FPC Target CPU-OS" I check i386-win32
4. Host x8664
5. Final params are "lin64 x86_64-linux xxxx i386 win32 xxxx" (I must set something in xxxx?)
6. Build
7. CT asking for password
8. Extracting something
9. Error like in attached screen (sorry, can't copy and paste)
I have the same problem, my configuration is Ubuntu 10.04.
How can i build cross element for win32 from linux?
