Error in open SQLQuery 2 years 8 months ago #18199
  • Ramon Retamar
  • Ramon Retamar's Avatar Topic Author
Hi.
I migrate a code from CT 7.0 to last version 8.2 without changes. The code is simple, and compile without problems in CT 7.0, but cause a SIGSEGV error en Open line:
Function TFDatos.Cantidad_de_informes_previos(DNI: String): Integer; // Contar la cantidad de estudios con observaciones
Begin
  With TSQLQuery.Create(Nil) Do
    Begin
      Try
        Screen.Cursor := crHourGlass;
        DataBase :=IBConnection2;
        Transaction := SQLTransaction4;
        SQL.Add('Select Count(DNI_PACIENTE) From ESTUDIOS Where (DNI_PACIENTE = ' + QuotedStr( DNI ) + ')' );
        Open;        /// ERROR !!!!
        Result := FieldByName('COUNT').AsInteger;
        Close;
      finally
        Free;
        Screen.Cursor := crDefault;
    End;
Strange, very strange. I try to rebuid project, clean and rebuid....and get the same error....only with CT 8.2
Thanks, Ramon
Last edit: by Ramon Retamar.
Error in open SQLQuery 2 years 8 months ago #18201
  • Thank you received: 228
Check "Client Libraries" location.
From CT 7.0 to 8.2 after 4 years, many things have changed...
Error in open SQLQuery 2 years 8 months ago #18204
  • Ramon Retamar
Thank you very much for answering. Where can I verify this option in the new version?
Ramon
Error in open SQLQuery 2 years 8 months ago #18205
Many SQL databases need more than one file to load and work.
So we added to ALL SQL databases the
Property ClientLibrary
Give then Client library (DLL for Win)
Test if ALL Options are OK (user name, pass, CharSet, etc)
Error in open SQLQuery 2 years 8 months ago #18206
  • Ramon Retamar
Thanks !!!!
I use the Firebiord 3.0 database, and client library is the fbclient.dll file located into executable folder. I check all database properties. Thanks !!!
