Patch for fpGUI integration... 11 years 11 months ago #6362
  • wolfram
  • wolfram's Avatar
The " automatic units adder" do not work (only tested on Win7).
The checkbox for "automatic units adder" ia enabled in uidesigner options.
Ah, ok!
The unused units are removed if they are no longer used.
BTW: Downlod of your videos work with MS IE but not with Firefox.
Last edit: by wolfram. Reason: I found the solution myself.
Patch for fpGUI integration... 11 years 11 months ago #6363
  • Fred
  • Fred's Avatar Topic Author
Aaaaargh, ok i will check it now... :blush:
Hum, by the way, the "Integration into IDE" is it working vice-verse in your Windows 7 system ?
Thanks.
Patch for fpGUI integration... 11 years 11 months ago #6364
  • wolfram
  • wolfram's Avatar
Sorry, I do not understan this question.
IDE integration is working. But what is "vice-verse" integration?
The following user(s) said Thank You: Fred
Patch for fpGUI integration... 11 years 11 months ago #6367
  • Fred
;) => I mean :
"vice" => You load a fpGUI file via Typhon and Typhon load that file in designer_ext.
When you save the file via designer_ext => You get a message from Typhon saying that the file has changed.
"versa" => You change something in code, save the file via Typhon => The file is reloaded into designer_ext.
Hum, i do not know how it is called so i call it "vice-versa" :blush:
About Auto Add Units =>
You are totally right, it was not working on Windows.
I have isolate the problem => LineEnding is not working in Windows.
=> I have post message to fpc forum and wait for answer.
But it will work, it is only a little problem =>
Give me one more white night and it is working. ;)
Many thanks to note it and for you patience.
Fre;D.
Last edit: by Fred.
Patch for fpGUI integration... 11 years 11 months ago #6368
  • Fred
=> Works now :) => github.com/fredvs/uidesigner_ext/
Ah, ok!
Hum, yes ;) ( not sure Lazarus designer does it... :blush: )...
Last edit: by Fred.
Patch for fpGUI integration... 11 years 11 months ago #6414
  • Fred
Hello everybody.
There is a new chapter in the fpGUI designer_ext movie...
=> Added skeleton for program, native and Java libraries...
Look it there =>
sites.google.com/site/designerext/fpgui_new_skeletons.mp4
PS: Tested Java program + library (the Java program is created as well) in
Linux, Windows and freeBSD => it works.
PS2: I would be very happy if somebody could try a java program + library
with Android (i do not have that machine).
PS3: Source and binaries of fpGUI designer_ext =>
[EDIT] Ooops, i forgot to commit the changes, now it is done...
Thanks.
Last edit: by Fred.
Patch for fpGUI integration... 11 years 6 months ago #7071
  • Graeme Geldenhuys
  • Graeme Geldenhuys's Avatar
fredvs wrote: Look it there =>
That is very impressive Fred, I definitely need to take a look at some of your changes. :)
Patch for fpGUI integration... 11 years 6 months ago #7083
  • Fred
Hello everybody.
New release of designer_ext.
Added patch for Typhon 5.2 and 5.3.
Also fixed some bugs.
PS : Here how to install all => www.pilotlogic.com/sitejoom/index.php/fo...gration?limitstart=0
Last edit: by Fred.
Patch for fpGUI integration... 11 years 5 months ago #7394
  • Fred
Hello everybody. :)
There is a new release of designer_ext => version 1.8
Added patch for Typhon 5.3 and 5.4.
Added assistive feature and much more...
In /bin => binary executable for Windows/Linux/freeBSD
PS2 . Designer_ext may be used as stand-alone too => not obliged to apply Typhon patch.
Last edit: by Fred.
Patch for fpGUI integration... 10 years 11 months ago #8579
  • Fred
Hello everybody. :)
There is a new release of designer_ext => version 1.9
Added => MultiSelect full duplex, better assistive, better ide integration and much more.
Added patch for Typhon 5.5.
=> www.github.com/fredvs/uidesigner_ext
Last edit: by Fred.
Patch for fpGUI integration... 10 years 10 months ago #8681
  • Fred
Hello everybody. :)
Added patch for CT 5.6 !
=> Better integration, better assistive, better all...
Last edit: by Fred.
