GetLocalTimeOffset return 0 5 years 6 months ago #15645
  • Vital
  • Vital's Avatar Topic Author
My zone - Moscow (+3), but function GetLocalTimeOffset return 0. Why?
OS: Ubuntu 21.04 (64-bit)
CT: 7.3
GetLocalTimeOffset return 0 5 years 6 months ago #15647
any sample for test
Did your set to your OS your local time ?
GetLocalTimeOffset return 0 5 years 5 months ago #15655
  • Vital
any sample for test
procedure showOffset;
  val: Integer;
  val:= GetLocalTimeOffset; // or any other with options
  ShowMessage(val.ToString);
Yes.
On Ubuntu 20.04 same problem as on Ubuntu 21.04. So not problem in OS.
Function Now() and NowUTC() return 0 both.
Last edit: by Vital.
GetLocalTimeOffset return 0 5 years 5 months ago #15656
  • Vbxler
  • Vbxler's Avatar
  • Thank you received: 5
I have tested the code above and get, as expected, -60 for the time offset of one hour.
Xubuntu 20.04 and latest CT.
GetLocalTimeOffset return 0 5 years 5 months ago #15657
Works as expected on Windows 10 as well, -60 for me being a Dutchman.
GetLocalTimeOffset return 0 5 years 5 months ago #15658
  • Vital
ShowMessage(DateTimeToStr(Now));
or
ShowMessage(DateTimeToStr(NowUTC));
Now 8:45 in Moscow (in systray), but functions Now() and NowUTC() show 5:45 both
GetLocalTimeOffset return 0 5 years 5 months ago #15659
  • Vbxler
  • Vbxler's Avatar
What do you get after entering: timedatectl
GetLocalTimeOffset return 0 5 years 5 months ago #15660
  • Vital
$ timedatectl
Local time: Пт 2021-03-12 12:16:24 MSK
Universal time: Пт 2021-03-12 09:16:24 UTC
RTC time: Пт 2021-03-12 09:16:24
Time zone: Europe/Moscow (MSK, +0300)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
GetLocalTimeOffset return 0 5 years 5 months ago #15668
  • Vital
Can I specify the time zone manually? Or how else can you force the compiled program to determine the correct timezone?
The project is on fire! We urgently need to do something!
GetLocalTimeOffset return 0 5 years 5 months ago #15671
  • firliri
  • firliri's Avatar
Hi, did you test the ReReadLocalTime function ?
GetLocalTimeOffset return 0 5 years 5 months ago #15673
  • Vital
firliri wrote: Hi, did you test the ReReadLocalTime function ?
  s: string;
  s:= DateTimeToStr(Now)+' UTC:'+DateTimeToStr(NowUTC)+#13#10;
  ReReadLocalTime;
  s+= (' ReReading:'+#13#10+DateTimeToStr(Now)+' UTC:'+DateTimeToStr(NowUTC));
  Label1.Caption:= s;
But real time in my timezone 14:27:21
GetLocalTimeOffset return 0 5 years 5 months ago #15677
  • Vital
Installed NeonOS KDE 5.21, the same problem :(
GetLocalTimeOffset return 0 5 years 5 months ago #15678
  • Vital
In Windows 10 it works as it should. In Ubuntu 20.04, Gnome 3.36 does not work as expected.
GetLocalTimeOffset return 0 5 years 5 months ago #15679
  • Vital
In Lazarus 2.0.12, fpc 3.2.0 works as it should
  s: string;
  s:= DateTimeToStr(Now)+' UTC:'+DateTimeToStr(LocalTimeToUniversal(Now));
  Label1.Caption:= s;
GetLocalTimeOffset return 0 5 years 5 months ago #15680
  • Vital
CT 7.0 works as it should.
There is no time to conduct more experiments. I remain until the delivery of the project on CT 7.0
GetLocalTimeOffset return 0 5 years 5 months ago #15691
after today update from FPC SVN: 49001   more info
With the above source, I get this
On Fedora 33 with the same Local time with your local time (UTC+3)
Just download from SVN the file :
rtl\unix\timezone.inc
and replace the CT file:
codetyphon/fpcsrc/rtl/unix/timezone.inc
Rebuild ALL (FPC and Typhon)
We try hard to offer "On User Side Real Time Support", but sometime we want help ...
The following user(s) said Thank You: firliri
GetLocalTimeOffset return 0 5 years 5 months ago #15702
  • 𝓚𝓸𝓭𝓮𝓩𝔀𝓮𝓻𝓰
  • 𝓚𝓸𝓭𝓮𝓩𝔀𝓮𝓻𝓰's Avatar
  • I do love ObjectPascal and WinApi
hello, i am new to CT and was searching for some practice.
i did played abit with code and for windows this solution came out, maybe usfull or not, you decide, for me just fun to do :)
program Project1;
uses Windows, SysUtils, DateUtils;
// include winapi methods
function TzSpecificLocalTimeToSystemTime(lpTimeZoneInformation: PTimeZoneInformation; var lpLocalTime, lpUniversalTime: TSystemTime): BOOL; stdcall; external kernel32 name 'TzSpecificLocalTimeToSystemTime';
function SystemTimeToTzSpecificLocalTime(lpTimeZoneInformation: PTimeZoneInformation; var lpUniversalTime, lpLocalTime: TSystemTime): BOOL; stdcall; external kernel32 name 'SystemTimeToTzSpecificLocalTime';
// convert local time to UTC
function DateTimeToUTC(const Local: TDateTime): TDateTime;
  TZI: TTimeZoneInformation;
  LocalTime,
  UniversalTime: TSystemTime;
  GetTimeZoneInformation(TZI);
  DateTimeToSystemTime(Local, LocalTime);
  TzSpecificLocalTimeToSystemTime(@TZI, LocalTime, UniversalTime);
  Result := SystemTimeToDateTime(UniversalTime);
// convert UTC to local time
function UTCToLocalDateTime(const UTC: TDateTime): TDateTime;
  LocalTime,
  DateTimeToSystemTime(UTC, UniversalTime);
  SystemTimeToTzSpecificLocalTime(@TZI, UniversalTime, LocalTime);
  Result := SystemTimeToDateTime(LocalTime);
// example usage
  Local,
  UTC: TDateTime;
  Local := Now;
  UTC := DateTimeToUTC(Local);
  WriteLn('Local:  ' + DateTimeToStr(Local));
  WriteLn('UTC:    ' + DateTimeToStr(UTC));
  WriteLn('Offset: ' + IntToStr(SecondsBetween(Local, UTC) div 60 div 60));
  ReadLn;
end.
GetLocalTimeOffset return 0 5 years 5 months ago #15703
  • Thank you received: 228
GetLocalTimeOffset return 0 5 years 5 months ago #15704
A big "Thanks" and from me Sir
Always we want your help,
it's a "critical factor" for us.
GetLocalTimeOffset return 0 5 years 5 months ago #15707
  • 𝓚𝓸𝓭𝓮𝓩𝔀𝓮𝓻𝓰
It's nice that you like what I've done there.
My source texts are unfortunately only suitable for windows.
Certainly there are methods in the existing libraries that achieve the same thing.
But I'm a little stubborn and usually go my own way.
I'll see what there is in the forum for questions.
If something appeals to me, especially with regard to windows and its api methods, i will tinker something.
If you are satisfied with what I offer, a small click on "thankyou" is enough to give me more incentive.
(For me, that reflects how well something is received or rejected.)
I don't want to violate forum rules, is there a kind of time limit until when you can answer a topic if you have perhaps found a better solution?
(I only picked this topic out because it was only a week old.)
Please forgive my spelling mistakes or the wrong sentence structure.
And please do not call me "Sir", call me KodeZwerg or in abbreviated form Kode.
The following user(s) said Thank You: Sternas Stefanos, Matis A.
