CT LAB ver 9.00 3 months 5 days ago #19645
We will check and update pl_ORCA with your code.
CT LAB ver 9.00 3 months 4 days ago #19646
  • Vbxler
  • Vbxler's Avatar
  • Thank you received: 5
Hello Mr. Sternas,
I would like to ask you whether its possible to integrate new controls?
forum.lazarus.freepascal.org/index.php/topic,74355.0.html
github.com/ACTom/TyControls
These controls have a modern look, which would improve the appearance of the GUI.
CT LAB ver 9.00 3 months 4 days ago #19647
From CT 9.00 (Current) you can find
pl_BGRATyControls
It's TyControls pkg ....
PS: LAB CT 9.10 (Unreleased)
has many new pkgs until now :
   -lz_Metafile
   -pl_MathParserGraph
   -pl_SedaiAudio
   -pl_TlsLib4Pascal
   -pl_TlsLib4PascalFclNet
   -pl_TlsLib4PascalIndy
   -pl_TlsLib4PascalmORMot
   -pl_TlsLib4PascalSynapse
   -pl_XelAudio
   -pl_XelComponents
   -pl_XelCompress
CT LAB ver 9.00 3 months 4 days ago #19648
  • Vbxler
  • Vbxler's Avatar
Thank you for your support!
CT LAB ver 9.00 3 months 3 days ago #19649
  • choki
  • choki's Avatar
I installed this new version on Fedora 44/KDE and haven't encountered any issues.
Great job :))
However, while using it, I’ve noticed a few issues:
- On non-QWERTY keyboards, Ctrl + Shift + N works, but Ctrl + N does not.
- I’m having trouble with copy/paste. CT refuses to paste text that was previously copied, even though I can paste it in Kate, for example. That’s very strange.
edit: I tested the copy-and-paste function again. Everything works perfectly when CT starts up. But at some point (I don't know when yet), it stops working.
To be continued...
- Is it possible to change the display of the context-sensitive help? In CT, it’s hard to read (see the attached images).
- Is it possible to increase the size of the component icons in the component palette?
Thanks for this excellent version.
Otherwise, I’m running Fedora 44/KDE.
CT version 9 revision 009000
i9/32GB
It's Wayland... Sir
Copy paste problem is not wayland, its Old bug when using QT widget (qt5/qt6), but never happen in GTK2,
please fix this annoying copy paste problem...
BTW, still using X11
thank
The following user(s) said Thank You: atlandev.ct
CT LAB ver 9.00 3 months 2 days ago #19652
We will try to fix this
CT LAB ver 9.00 2 months 4 weeks ago #19654
  • LuZZZZi
  • LuZZZZi's Avatar
Sorry, nonsense. All works ok.
Last edit: by LuZZZZi.
Cannot copy text from object inspector 1 month 3 weeks ago #19675
  • choki
  • choki's Avatar
I'm trying to copy the color property value from the ObjectInspector and paste it into the editor, but it won't paste. Even though it works perfectly fine in other text editors. The same issue also happens with other properties like captions.
QT6
Machine: manjaro.
Reproduce:
  1. new project
  2. change form color to custom color ex:#7c6158 from color chooser/selector
  3. double click color value to copy, when couble click the color value change automatically to clBlack
  4. after that, nothing cannot copy from object inspector to editor, including just copy caption "Form1"
Last edit: by choki.
Cannot copy text from object inspector 1 month 3 weeks ago #19678
Yes, this is a problem.
We will try to fix it.
