CT LAB ver 8.00 3 years 10 months ago #17463
CT 8.0 final installed on Windows 10, went as clockwork!
No problems found so far.
Linux Mint 21 will be done tomorrow.
CT LAB ver 8.00 3 years 10 months ago #17469
CT 8.0 Final installed on Linux Mint 21.1 without problems as well.
The following user(s) said Thank You: Matis A.
CT LAB ver 8.00 3 years 10 months ago #17472
  • Leonid
  • Leonid's Avatar
  • Thank you received: 4
CT 8.0 latest version. Tested using the virtual distribution xubuntu 2022-04.
Checked all my projects (gtk2, pl_RX, pl_FpSpreadsheet, lz_SQLdb, lz_taChart).
Everything works.
Found a problem with lz_Report. I checked the filters for exporting to PDF format.
In version CT 7.9, all three work fine, but in version CT 8.0, cairo-export displays
a portrait instead of landscape.
The main system is debian 11, where I continue to use CT 7.9 for everyday work.
Best regards
CT LAB ver 8.00 3 years 9 months ago #17482
  • skrzat
  • skrzat's Avatar
There is bug in finding key combination in "Key Mappings"
Every time I install new version of CT I have to clear 4 key combinations (Ctrl+Alt+S, Ctrl+Alt+L, Ctrl+Alt+X, Ctrl+Alt+C). These combinations are default in Windows to enter Polish characters.
In every older version of CT I clicked "Find New Combination", then "Grab key" and OK. After this procedure list was limited to item with such a key combination. It doesn't work in CT 8.00. I had to enter manually i.e. Ctrl+Alt+S in filter control.
Windows 11 64bit
CT LAB ver 8.00 3 years 9 months ago #17484
  • Leonid
  • Leonid's Avatar
Installed CT 8.0 on the main system debian 11 with KDE (although now I lost access to codetyphon, GLIBC < 2.34).
There are no problems with PDF cairo-export. I also checked CT 8.0 on the Windows 7 32 bit virtual machine,
everything is fine there too.
Apparently the problem is only present in xubuntu 2022-04 or is it related to Xfce desktop environment.
Best regards
