CT LAB ver 6.50 8 years 5 months ago #11716
Did you set in Object Inspector TitleStyle property to tsStandard etc
CT LAB ver 6.50 8 years 5 months ago #11717
  • Fernando
  • Fernando's Avatar
I start a new project, drop a TsWorksheetGrid there and the top row appears empty, i.e. the titles A, B, C, etc. are missing.
Changing TitleStyle to any of the three options changes the appearance of top row and left column, but do not affect the titles.
The same happens opening sample spreadsheet projects. Tested in windows and linux, after installing CT 6.5 with remove and build all.
CT LAB ver 6.50 8 years 5 months ago #11718
Please Sir
give us time to fix this
The following user(s) said Thank You: Fernando
CT LAB ver 6.50 8 years 5 months ago #11738
  • Fernando
  • Fernando's Avatar
Perhaps this may help with the spreadsheet issue:
The event OnGetColHeaderText now can be succesfully created but never gets fired, it looks like row 0 is never accessed to write text when painting.
CT LAB ver 6.50 8 years 5 months ago #11739
Fixed in lazccr
Attach fixed pl_FPSpreadsheet version 6.6.1
just replace your pkg
CT LAB ver 6.50 8 years 5 months ago #11741
  • Fernando
  • Fernando's Avatar
Thanks, sir!
It works well now
CT LAB ver 6.50 8 years 3 months ago #11899
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
Hallo Sir,
maybe I found something new to my problem. The zero-filled debugger is shown in my specific case only in zeos-versions with
xint64 : UInt64; //=== ct9999 ============
lines in core\ZFastCode.pas.
I did everything to find the right line, the error occurs, but no success.
Could this cause the debugger-behaviour?
CT LAB ver 6.50 8 years 3 months ago #11900
I am not so sure
and the latest pl_ZeosDBO update before 15 min
pl_ZeosDBO-2018-07-29.7z
please try and report
CT LAB ver 6.50 8 years 3 months ago #11901
  • Klaus Riesterer
Sorry, did not work here. Same result.
Last working version I have is 6.0.1
CT LAB ver 6.50 8 years 2 months ago #11935
  • Klaus Riesterer
Why do you use Zeos 6.6.x when there is 7.2.x out?
sourceforge.net/projects/zeoslib/files/Z...0Database%20Objects/
CT LAB ver 6.50 8 years 2 months ago #11936
Sir, one small note,
ZEOS 6.6.x is CodeTyphon package number (from CT ver 6.60)
ALL CT packages have the same number with CT release.
CT always use SVN trunk sources and in case of ZEOS the "Internal pkg version" now, is 7.3.x
CT LAB ver 6.50 8 years 2 months ago #11938
  • Klaus Riesterer
Thank you.
