CT LAB ver 5.10 12 years 3 weeks ago #6108
Sir can you give as more info for this problem ?
CT LAB ver 5.10 12 years 3 weeks ago #6109
  • XANDR
  • XANDR's Avatar
1. In the asm file cprt0.as located in c:\codetyphon\fpcsrc\rtl\linux\arm\ is missed next four lines:
.type _init,%function
.type _fini,%function
.weak _init
.weak _fini
this lines needs when buildin the arm-linux target with cthreads support.
2. I think the issue bugs.freepascal.org/view.php?id=24056 was closed without real fix the file. I created another one ticked: bugs.freepascal.org/view.php?id=26869.
It is all what i known.
Last edit: by XANDR.
CT LAB ver 5.10 12 years 3 weeks ago #6111
Your project Target-CPU-OS ?
How do you build the FPC Cross-element ? Did you use CTCenter for what ?
What units or Libraries use your project ?
Did you use CT OS-Libraries ?
etc...
CT LAB ver 5.10 12 years 3 weeks ago #6116
  • David
  • David's Avatar
Sr Updated to last lab 5.021, build all, and Downloaded toolchain again.
But now, doing fpc32 cross build element arm-cubieboard fail with errors
       Stage 2: Build All Units and Packages
make[2]: Leaving directory `C:/codetyphon/fpcsrc/compiler'
make[1]: Leaving directory `C:/codetyphon/fpcsrc/compiler'
make: Entering directory `C:/codetyphon/fpcsrc/utils/fpcm'
C:/codetyphon/fpc/fpc32/bin/i386-win32/gmkdir.exe -p units/i386-win32
ppc386.exe -dREVINC -Fu../../rtl/units/i386-win32 -Fu../../packages/rtl-objpas -Fu../../packages/hash -Fu../../packages/paszlib -Fu../../packages/fcl-process -Fu../../packages/libtar -Fu../../packages/fpmkunit -Fu../../packages/fcl-res -Fu../../packages/fcl-base -FE. -FUunits/i386-win32 -di386 fpcmwr.pp
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\system.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\objpas.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\sysutils.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\windows.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\sysconst.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\windirs.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\classes.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\rtlconsts.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\types.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\typinfo.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\dos.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\strings.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2014/10/16 22:38:42); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
fpcmdic.pp(71,1) Fatal: There were 12 errors compiling module, stopping
Fatal: Compilation aborted
make: *** [fpcmwr.ppu] Error 1
CT LAB ver 5.10 12 years 3 weeks ago #6119
  • XANDR
  • XANDR's Avatar
I use next options:
Target-CPU-OS: arm-linux
Host: Win7 64 bit. 32Bit big IDE.
The FPC Cross-element was builded from CTCenter;
Library: arm-linux-pi
For reproduce the bug: simple console app with use cthreads unit.
I hope this info will be useful
CT LAB ver 5.10 12 years 3 weeks ago #6120
my suggestion :
-Install-Build LAB CT 5.10
-Download win32-arm-linux--RapberryPi and build FPC32 Cross-Element
-Download arm-linux-Raspbian OS-Library
and test your application
We build and test "any" arm-linux application without problem
CT LAB ver 5.10 12 years 3 weeks ago #6121
  • XANDR
  • XANDR's Avatar
Thanks for your suggestion, I will try this. But I have a question: If I builded (for example) three cross elements and downloaded three libraries, how i can select one of this?
CT LAB ver 5.10 12 years 3 weeks ago #6122
For OS-Libraries NO problem
For FPC elements: is in our To-Do list for future CT ver 5.20...
We want time and help...
CT LAB ver 5.10 12 years 3 weeks ago #6124
  • XANDR
  • XANDR's Avatar
sternas, thanks for your answers
CT LAB ver 5.10 12 years 3 weeks ago #6126
  • David
  • David's Avatar
hi
crosscompiling to cubieboard now working with 5021
Just download again 5.0, and updated to last lab 5021, then fpc crossbuild sucessfully.
CT LAB ver 5.10 12 years 1 week ago #6181
  • Vbxler
  • Vbxler's Avatar
I can not start the application typhone32 5.1. I get the message: Access violation.
I use Win7x64
Last edit: by Vbxler.
CT LAB ver 5.10 12 years 1 week ago #6182
Open Task Manager end close all Typhon executables
and please try CT 5.10 final...
CT LAB ver 5.10 12 years 1 week ago #6190
  • Vbxler
  • Vbxler's Avatar
Thank you, the reason was a faulty environmentoptions.xml file.
Now it works!
CT LAB ver 5.10 12 years 1 week ago #6191
Please report any problem
and have fun...
