App launches and then dies the moment you click 12 years 4 months ago #4631
  • trustfm
  • trustfm's Avatar Topic Author
Hello .
I am currently using the following configuration
CodeTyphon 4.5
with
installer_r22.0.5-windows (sdk)
and the
android-ndk-r7c-windows version
I compile correctly the "androidlcl" demo . I can also generate the apk package but when i launch it on the virtual device
whenever i click on a control like a Tbutton the app crashes.
I have read the www.pilotlogic.com/sitejoom/index.php/93...ss-build-for-android
tutorial.
The hole "androidlcl" project can be found here :
dl.dropboxusercontent.com/u/28434419/androidlcl.zip
The logcat is here :
pastebin.com/An984GvW
Can someone help me ?
Thanks for your time !
Last edit: by trustfm.
App launches and then dies the moment you click 12 years 4 weeks ago #5108
  • sax
  • sax's Avatar
I'm currently using CodeTyphon 4.7, android-ndk-r9b-windows-x86, sdk installer_r22.3-windows,jdk1.6.0_38.
In CodeTyphon I'm using Library: C:\Android\ndk\platforms\android-8\arch-arm\usr\lib\ and in apk buil script I'm using:
SET PATH=C:\Android\sdk\tools;C:\Android\sdk\platform-tools\;C:\Android\sdk\build-tools\19.0.1\;C:\Progra~1\Java\jdk1.6.0_38\bin
SET APP_NAME=androidlcltest
SET ANDROID_HOME=C:\Android\sdk
SET APK_SDK_PLATFORM=C:\Android\sdk\platforms\android-8
SET APK_PROJECT_PATH=.
My Android virtual device is:
Android 2.3.3 and API level is 10, CPU is ARM(armeabi).
Application starts on virtual device and when I cklick on form crashes!
Does anyone know what could be wrong?
App launches and then dies the moment you click 12 years 4 weeks ago #5109
  • sam
  • sam's Avatar
looks like the same problem here: ( see the end of the thread)
Thread in Lazarus Android Forum
If you find out, let us know.
Thank you.
App launches and then dies the moment you click 12 years 4 weeks ago #5113
  • Aleksandar
  • Aleksandar's Avatar
  • Thank you received: 31
sax wrote: I'm currently using CodeTyphon 4.7, android-ndk-r9b-windows-x86, sdk installer_r22.3-windows,jdk1.6.0_38.
EDIT:
Included script for making .apk is not good anymore. It needs to be changed, since apkbuilder tool is removed from SDK. "Aapt add" can be used to add classes.dex to unisigned.apk.
You can compile java part and make apk with ANT too.
Java part of project needs to be checked.
I removed some of my comments since I realized that they are not useful.
Same crash here with CT 4.70 and JDK 7u51. I will try few more things tomorrow.
Last edit: by Aleksandar.
App launches and then dies the moment you click 12 years 3 weeks ago #5127
  • Aleksandar
sam wrote: Hi,
Thank you.
Looks like some change in latest versions of FPC is cause of all those crashes.
I managed to make working android application using some files from older FPC.
I put archive with used files on dropbox . Use them only as temporary solution until someone find how to solve this properly.
1.Backup c:\codetyphon\fpc\bin and c:\codetyphon\fpc\units folders
2. Replace ppcrossarm.exe in c:\codetyphon\fpc\bin\i386-win32 with the one from archive
3. Remove c:\codetyphon\fpc\units\arm-android and replace it with the one from the archive
4. Delete folder c:\codetyphon\typhon\lcl\units\arm-android - it will be recreated on first compile of lcl app for android
Be sure that you set Target file name to android\libs\armeabi\liblclapp.so, that you added correct path to Android NDK in Labraries and that you set Target OS to Android and Target CPU to ARM.
Build project and check if you have liblclapp.so in c:\codetyphon\CodeOcean\2_Basics\samples\androidlcl\android\libs\armeabi
When you finish with this, you have working .so library and you are ready to follow the steps for making APK that I post earlier today.
The following user(s) said Thank You: sax
App launches and then dies the moment you click 12 years 3 weeks ago #5130
  • sax
  • sax's Avatar
THX viking.
I finally managed to have working .apk on emulator! :)
Only problem was that I have using jdk1.7.0_51, because in JDK 7, default signing algorithim has changed, requiring you to specify the signature and digest algorithims (-sigalg and -digestalg) when you sign an APK.
When I install .apk on emulator I got error
Failure [INSTALL_PARSE_FAILED_NO_CERTIFICATES]
Then I have to change JDK 7 to JDK 6 and is install correctly (or add "I think" -sigalg and -digestalg in jarsigner command, sigalg="MD5withRSA" digestalg="SHA1").
App launches and then dies the moment you click 12 years 3 weeks ago #5132
  • Aleksandar
It works just fine with 7u51. Just delete your already generated key and crate new one with JDK 7. :)
EDIT: I forgot to ask one important question. Have you used files from my archive or you managed to get working .so library with default files from CT 4.7?
App launches and then dies the moment you click 12 years 3 weeks ago #5137
  • sax
  • sax's Avatar
I use files from your archive.
If I generate .apk file with this settings, JDK 1.6 (build_debug_apk.bat)
SET JAVA_HOME="C:\Program Files\Java\jdk1.6.0_38"
REM Generating on the fly a debug key
keytool -genkey -v -keystore bin\LCLDebugKey.keystore -alias LCLDebugKey -keyalg RSA -validity 10000 -dname "CN=Jonh Doe" -storepass senhas -keypass senhas
REM Signing the APK with a debug key
del bin\%APP_NAME%-unaligned.apk
jarsigner -verbose -keystore bin\LCLDebugKey.keystore -keypass senhas -storepass senhas -signedjar bin\%APP_NAME%-unaligned.apk bin\%APP_NAME%-unsigned.apk LCLDebugKey
then I can successfully install .apk
C:\codetyphon\Projects\New_Empty\android>adb install bin\androidlcltest.apk
102 KB/s (740483 bytes in 7.056s)
        pkg: /data/local/tmp/androidlcltest.apk
Success
If I change JDK version to 1.7, like this (leave the rest of the code the same)
SET JAVA_HOME="C:\Program Files\Java\jdk1.7.0_51"
then I get installer error
237 KB/s (740687 bytes in 3.049s)
and if I now change jarsigner to
jarsigner -verbose -sigalg MD5withRSA -digestalg SHA1 -keystore bin\LCLDebugKey.keystore -keypass senhas -storepass senhas -signedjar bin\%APP_NAME%-unaligned.apk bin\%APP_NAME%-unsigned.apk LCLDebugKey
then .apk installs correctly.
Last edit: by sax.
App launches and then dies the moment you click 12 years 3 weeks ago #5144
  • Aleksandar
sax wrote: If I change JDK version to 1.7, like this (leave the rest of the code the same)
It is very simple.
If you already have keystore, then this line will fail with message like this:
c:\codetyphon\CodeOcean\2_Basics\samples\androidlcl\android>keytool -genkey -v -
keytool error: java.lang.Exception: Key pair not generated, alias <LCLDebugKey>
already exists
Just delete c:\codetyphon\CodeOcean\2_Basics\samples\androidlcl\android\bin\LCLDebugKey.keystore that you generated with 1.6 first and then new one with be created with 1.7 if you have that line uncommented.
Then you will get something like this:
Generating 2,048 bit RSA key pair and self-signed certificate (SHA256withRSA) wi
th a validity of 10,000 days
        for: CN=Jonh Doe
[Storing bin\LCLDebugKey.keystore]
and then
c:\codetyphon\CodeOcean\2_Basics\samples\androidlcl\android>jarsigner -verbose -
in\androidlcltest-unaligned.apk bin\androidlcltest-unsigned.apk LCLDebugKey
   adding: META-INF/MANIFEST.MF
   adding: META-INF/LCLDEBUG.SF
   adding: META-INF/LCLDEBUG.RSA
  signing: lib/armeabi/liblclapp.so
  signing: AndroidManifest.xml
  signing: resources.arsc
  signing: res/drawable-hdpi/icon.png
  signing: res/drawable-ldpi/icon.png
  signing: res/drawable-mdpi/icon.png
  signing: classes.dex
jar signed.
p.s. Yes, I could add
del bin\LCLDebugKey.keystore
but I didn't want to be blamed if someone lost his properly created key because of that.
App launches and then dies the moment you click 12 years 1 week ago #5199
  • Leslie
  • Leslie's Avatar
  • Thank you received: 4
I have a fresh install of CT 4.70. Replaced everything as suggested above. Compilation fails with the following error:
PPU Loading C:\codetyphon\typhon\components\lazutils\lib\arm-android\lazlogger.ppu
PPU Invalid Version 164
lclproc.pas(32,28) Fatal: Can not find LazLogger used by LCLProc, ppu=..\components\lazutils\lib\arm-android\lazlogger.ppu, package LazUtils
Any idea where could I be going wrong?
Cheers,
Leslie
The following user(s) said Thank You: sam
App launches and then dies the moment you click 11 years 11 months ago #5259
  • Leslie
  • Leslie's Avatar
After compiling the crosscompiler from the latest SVN source and rebuilding all involved FPC&CT units, the problem remains the same. My understanding was that this has ben fixed in FPC SVN. Is this working with he lab version of CT? (By the way, is there an approximate release date?)
Cheers,
Leslie
App launches and then dies the moment you click 11 years 11 months ago #5260
  • Leslie
  • Leslie's Avatar
As I understand there is a not too old FPC revision which is known to be able to create a working android test application. Anyone remembers wich revision is it?
Last edit: by Leslie.
App launches and then dies the moment you click 11 years 11 months ago #5263
  • Aleksandar
Leslie wrote: My understanding was that this has ben fixed in FPC SVN. Is this working with he lab version of CT?
Where did you get that info?
Bug report submitted by our friend Sam is still open.
Based on Maciej's comment and the fact that Simon's Native Android Controls work without any problem, it is 99% LCL or even JAVA bug.
Leslie wrote: As I understand there is a not too old FPC revision which is known to be able to create a working android test application. Anyone remembers wich revision is it?
I posted older FPC version in this post as temp workaround.
The following user(s) said Thank You: Leslie
App launches and then dies the moment you click 11 years 11 months ago #5264
  • Leslie
  • Leslie's Avatar
Hi Viking,
I obviously misunderstood something. :unsure:
The first thing I have tried was your suggestion. But I got stucked with the problem you can see in post #5199
If you can share the FPC revision the files you have provided had been compiled with, I might be able to get it working.
Cheers,
Leslie
App launches and then dies the moment you click 11 years 11 months ago #5269
  • Aleksandar
Leslie wrote: Hi Viking,
Cheers,
Leslie
It worked for me with files that I posted.
Since sax successfully compiled apk, that only means that my instructions might not be clear enough.
I really do not have time to experiment and to try to find what could be reason for your problem.
And regarding the FPC version, any versions around 2013-5-12 should be fine.
App launches and then dies the moment you click 11 years 11 months ago #5272
  • Leslie
  • Leslie's Avatar
Viking,
I am not expecting you to solve this problem. Though I appreciate any help/info I can get. If you do not have the time feel free to stay out of the topic. :)
What I have discovered so far:
Handling the touch event invalidates the display. As a result a redraw takes place and the crush occurs whithin Java_com_pascal_lclproject_LCLActivity_LCLDrawToBitmap. I would try to investigate further, but could not find a way to debug the pascal part when running on android. If someone could help with this - if it is possible at all- that would be great.
Cheers,
Leslie
App launches and then dies the moment you click 11 years 10 months ago #5347
  • sam
  • sam's Avatar
I still try to find the problem on this issue. But I need your help.
See my last question on this bug.
Bug Tracker #25686
In short:
1.) I have two fpc-folders.
2.) Compile with fpc-folder A creates an working android app.
3.) Compile with fpc-folder B creates an non-working android app. ( problem as decribed in this thread)
My attempt to find the differences between fpc-folder A and fpc-folder B.
1.) I took a folder-compare program that shows about 4000 differences. (compare all files)
My questions:
A) Which files are files are temporary files only (.ppu,.o) and can be delete before the folder compare is done?
B) If I delete all .ppu files first and then try to compile my app again, lazarus complains about missing system.ppu. What to do? Some how recompile fpc?
Thank you for your answers.
App launches and then dies the moment you click 11 years 10 months ago #5348
  • Leslie
  • Leslie's Avatar
Finally I had some time to investigate this problem. The problem was NOT caused by the compiler. The faulty code is in customdrawnproc.RenderWinControl:
ACanvas.ClipRegion := ACDWinControl.Region;
In this line a reference is stored to an other objects property. Which did not cause a problem until FPC r24555, when a memory leak caused by not freeing TFPCustomCanvas.FClipRegion in TFPCustomCanvas destructor was fixed. From this point destroying the canvas object destroyed ACDWinControl.Region.
The solution is to create a separate object:
function RenderWinControl(var AImage: TLazIntfImage; var ACanvas: TLazCanvas;
ACDWinControl: TCDWinControl; ACDForm: TCDForm): Boolean;
lRegion : TLazRegionWithChilds; <-- add a local variable
// --> replace the faulty line above with this
lRegion := TLazRegionWithChilds.Create;
lRegion.Assign(ACDWinControl.Region);
ACanvas.ClipRegion := lRegion;
"c:\codetyphon\typhon\lcl\units\arm-android\customdrawn\" probably needs to be cleared before rebuilding the test application with "Clean up and build ..." .
Cheers,
Leslie
App launches and then dies the moment you click 11 years 10 months ago #5349
  • sam
  • sam's Avatar
Well done leslie, you fixed the problem.
Great. Thanks.
App launches and then dies the moment you click 11 years 10 months ago #5350
  • Dinko
  • Dinko's Avatar
  • Thank you received: 5
Thank you very much.
I can confirm that this solution is OK.
I made a test with CT 4.7 Win32
Location of customdrawnproc.pas file is in
c:\codetyphon\typhon\lcl\interfaces\customdrawn\ directory
Best Regards, Dinko
