arm-linux raspberry pi 12 years 2 months ago #5920
  • zeljko
  • Thank you received: 38
install debian 7 32
codetyphon 4.92
linux arm
library arm-linux-pi
NOT WORK arm-linux
Compile Project: Exit code 256, Errors:1
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: warning: link.res contains output sections; did you forget -T?
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: skipping incompatible /usr/lib/i386-linux-gnu/crti.o when searching for /usr/lib/i386-linux-gnu/crti.o
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: cannot find /usr/lib/i386-linux-gnu/crti.o
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: skipping incompatible /usr/lib/gcc/i486-linux-gnu/4.6/crtbegin.o when searching for /usr/lib/gcc/i486-linux-gnu/4.6/crtbegin.o
/usr/lib/codetyphon/fpc/bin/i386-linux/arm-linux-ld: cannot find /usr/lib/gcc/i486-linux-gnu/4.6/crtbegin.o
project1.lpr(22,0) Error: Error while linking
Last edit: by zeljko.
arm-linux raspberry pi 12 years 2 months ago #5963
we solve the problem with RapberryPi
we test
-Build FPC32 Cross Element with ToolChain win32-arm-linux--RapberryPi.7z (is in our Web ToolChains library)
-Build application for RapberryPi (arm-linux) on windows (Typhon32) with OS Library arm-linux-Raspbian.7z (is in our Web OS libraries)
-Run on QEMU with 2014-06-20-wheezy-raspbian.img
soon our test on Linux
Here is the Windows Crossbuild script x_FPC_Build_Cross_arm_linux_RapberryPi.bat
put this to C:\codetyphon\ScriptsWin\crossbuild directory
arm-linux raspberry pi 12 years 1 month ago #6008
  • FredyCC
  • FredyCC's Avatar
  • Database/Developer
  • Thank you received: 10
Hi sternas, I followed your instructions above without success. :(
Config:
  • CodeTyphon ver5.0 for Win64
  • FPC for Win32
Compile Project: Exit code 1, Errors: 1
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: warning: link.res contains output sections; did you forget -T?
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhonTemp\lib\arm-linux\project1.o has EABI version 0, but target C:\codetyphon\typhonTemp\project1 has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhonTemp\lib\arm-linux\project1.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\system.o has EABI version 0, but target C:\codetyphon\typhonTemp\project1 has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\system.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\lineinfo.o has EABI version 0, but target C:\codetyphon\typhonTemp\project1 has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\lineinfo.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\exeinfo.o has EABI version 0, but target C:\codetyphon\typhonTemp\project1 has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\exeinfo.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\strings.o has EABI version 0, but target C:\codetyphon\typhonTemp\project1 has EABI version 5
Thanks in advance
Last edit: by FredyCC.
arm-linux raspberry pi 12 years 1 month ago #6009
Sir, please wait 2-3 days for Lab CT 5.10
we solve a lot of these problems
We Crossbuild applications on Host OSes Windows, Linux and FreeBSD...
and we test these applications on QEMU with 2014-06-20-wheezy-raspbian.img
Now we working 4 programmers on "Embedded Form Designer"
on Host with GTK2 Platform, we must make a "Virtual MainMenu"
All OK on Hosts with Windows and QT Platforms
The following user(s) said Thank You: FredyCC, David
arm-linux raspberry pi 12 years 1 month ago #6013
  • FredyCC
  • FredyCC's Avatar
After many hours and attempts, I was able to successfully compile on Ubuntu (i386) to Raspbian (arm). :woohoo:
The problem is related to the gcc version, the version that worked to generate the executable was: gcc 4.2.3
Although the output generated is:
Hint: (11030) Start of reading config file /usr/lib/codetyphon/fpc/bin/i386-linux/fpc.cfg
Hint: (11031) End of reading config file /usr/lib/codetyphon/fpc/bin/i386-linux/fpc.cfg
Free Pascal Compiler version 2.7.1 [2014/09/25] for arm
(1002) Target OS: Linux for ARMEL
(3104) Compiling project1.lpr
(3104) Compiling unit1.pas
/home/fredycc/Desktop/test/unit1.pas(9,3) Hint: (5023) Unit "Spin" not used in Unit1
/home/fredycc/Desktop/test/unit1.pas(9,9) Hint: (5023) Unit "ExtDlgs" not used in Unit1
(9009) Assembling unit1
(9009) Assembling project1
(9022) Compiling resource /home/fredycc/Desktop/test/lib/arm-linux/project1.or
(9015) Linking project1
project1.lpr(22) Warning: (9034) "crti.o" not found, this will probably cause a linking failure
project1.lpr(22) Warning: (9034) "crtbegin.o" not found, this will probably cause a linking failure
project1.lpr(22) Warning: (9034) "crtend.o" not found, this will probably cause a linking failure
project1.lpr(22) Warning: (9034) "crtn.o" not found, this will probably cause a linking failure
(1008) 57 lines compiled, 2.2 sec
(1021) 4 warning(s) issued
(1022) 4 hint(s) issued
The executable builds successfully without the crti.o files and runs on raspberry device.
CT 5.0 looks beautiful on Ubuntu ;)
arm-linux raspberry pi 12 years 1 month ago #6014
For
use the latest arm-linux-Raspbian.7z Library
The Lab CT ver 5.10 has full support for Rapberry Pi and Raspbian
ETA soon...
arm-linux raspberry pi 12 years 2 weeks ago #6152
  • yenwei
  • yenwei's Avatar
I have tested , but can not connect to server. How to do it?
arm-linux raspberry pi 12 years 2 weeks ago #6153
  • yenwei
  • yenwei's Avatar
In windows, compiler stop in "gtk2cellrenderer.pas(30,3) Fatal: Cannot find unit gtk2 used by Gtk2CellRenderer of package LCL."
arm-linux raspberry pi 12 years 2 weeks ago #6154
Please Sir
use lab CT 5.10
arm-linux raspberry pi 12 years 2 weeks ago #6156
  • yenwei
  • yenwei's Avatar
:( I also hope that I can use lab CT 5.10, but still only CT 5.00 can be downloaded at the website.
arm-linux raspberry pi 12 years 2 weeks ago #6157
You can use update procedure from CTCenter
on Ubuntu you must give full "sudo" permissions to current user look here
We working on lab CT 5.10 beta1 now
arm-linux raspberry pi 12 years 1 week ago #6201
  • yenwei
  • yenwei's Avatar
Yesterday, I get the lab CT5.10 from CTCenter.
But the package "DATAPORT", component "Serial".It is still cross compiler with Error.
Compiling package pl_synapse 40.1.8: Exit code 1, Errors: 13
synaser.pas(259,15) Error: Identifier not found "B500000"
synaser.pas(259,22) Error: Illegal expression
synaser.pas(265,15) Error: Identifier not found "B2000000"
Anyway,
I want say thanks for here,for every one.
arm-linux raspberry pi 12 years 1 week ago #6203
We will check this Sir
