uebutton in CT Lab version 7.70 2 years 2 months ago #16598
  • Javier
  • Javier's Avatar Topic Author
Hi
I just installed CT Lab version 7.70 in Windows 10 and it looks like "uebutton" is missing or deprecated
Could you help me on it?
Thank you
uebutton in CT Lab version 7.70 2 years 2 months ago #16599
  • Thank you received: 148
Yes,
pl_BGRAuecontrols package Removed from LAB CT ver 7.70.
Use components from other pl_BGRAxxxx packages.
uebutton in CT Lab version 7.70 1 year 7 months ago #17265
  • Alex
  • Alex's Avatar
Hello, I have just updated to 7.8 and have this same issue. I have 4 year old project that a lot of work went for and it has a lot depending on pl_BGRAuecontrols , but now everything doesnt work because that was removed. Is there a way to add that package back manually?
Thanks!
uebutton in CT Lab version 7.70 1 year 7 months ago #17266
You can copy pl_BGRAuecontrols from CT 7.0 to CT 7.80.
Install pkg and and rebuild Typhon IDE
uebutton in CT Lab version 7.70 1 year 7 months ago #17271
  • Alex
  • Alex's Avatar
That is actually what I have been trying to do but so far was not successful. Anyway you could please assist with that? Thanks!
uebutton in CT Lab version 7.70 1 year 7 months ago #17272
  • Alex
  • Alex's Avatar
What I have done is copied pl_BGRAuecontrols folder into C:\codetyphon\typhon\components. I did go to New Package (under packaga), added pl_bgrauecontrols.ctpkg inside the copied pl_BGRAuecontrols folder. It asked to rebuild ide, I did that and when I go to build my app, I get:
mainunit.pas(9,59) Error: Cannot find uETileImage used by mainUnit, incompatible ppu=C:\codetyphon\typhon\components\pl_BGRAuecontrols\lib\x86_64-win64\win32\uetileimage.ppu, package pl_bgrauecontrols
Last edit: by Alex.
uebutton in CT Lab version 7.70 1 year 7 months ago #17273
Close TyphonIDE
Copy pl_BGRAuecontrols to
C:\codetyphon\typhon\components\packages_pl\
folder
Open TyphonIDE and Open pl_BGRAuecontrols pkg, NOT new pkg
-Build pl_BGRAuecontrols Pkg
-Install pl_BGRAuecontrols Pkg
-Rebuild TyphonIDE
uebutton in CT Lab version 7.70 1 year 7 months ago #17279
  • Jens
  • Jens's Avatar
I did it another way. I wrote myself a converter to update my old projects. Replacements in ctpr, ppr, frm and pas files are necessary. Since I used only "TuELED" from BGRAuecontrols in the past, its not a big thing. The biggest advantage for me is, there is no need to install old packages in new CT versions.
What I did:
  • replace all "pl_BGRAuecontrols" with "pl_BGRAextra" in all .ppr and .ctpr files
  • replace all "TuELED" with "TbgraLedEx" in all .frm and .pas files
  • replace all "ueled" with "gbraExLed" in all .pas files
I don't know if this works for all (BGRAue..) components in the same way.
Jens
Last edit: by Jens. Reason: typo
uebutton in CT Lab version 7.70 1 year 7 months ago #17281
Thanks, have fun
