× Discussions for CodeTyphon Studio Installation and Setup.
Question Problems in WINDOWS 10 and DIRECTX (d3d9.dll)
  • Jürgen Abel
  • Jürgen Abel's Avatar Topic Author
  • Fresh Boarder
  • Fresh Boarder
  • PASCAL Enthusiast
4 months 1 week ago #11915 by Jürgen Abel
Problems in WINDOWS 10 and DIRECTX (d3d9.dll) was created by Jürgen Abel
Hello!
After updating from WINDOWS 7 to WINDOWS 10, the compiler typhon32 and typhon 64 doesn't start anymore.
When typhon32 is started, two times a message appears that a subroutine SfmDxGetSwapChainStats in d3d9.dll can't be found.
After this message, I tried everything I could:
Deinstalled old CodeTyphon Studio,
Installed newest DirectX12 from directx_Jun2010_redist.exe, the installation runs smoothly without any error,
Installed System Libraries from CodeTyphon Studio 6.5,
Installed CodeTyphon Studio 6.5 (Remove and build All).
The error message is still there when starting typhon32.
What else can I try?
4 months 1 week ago #11916 by Sternas Stefanos
Replied by Sternas Stefanos on topic Problems in WINDOWS 10 and DIRECTX (d3d9.dll)
If Small Typhon IDE Work OK then I think it's dll problem
please
read this
The following user(s) said Thank You: Jürgen Abel
  • Jürgen Abel
  • Fresh Boarder
  • Fresh Boarder
  • PASCAL Enthusiast
4 months 1 week ago #11917 by Jürgen Abel
Replied by Jürgen Abel on topic Problems in WINDOWS 10 and DIRECTX (d3d9.dll)
Thanks for the hint.
The problem seemed to be virtualbox guest additions, which kept an old d3d9.dll.
Here is what I did to solve the problem, everything in cmd.exe with administrator rights:
run "DISM /Online /Cleanup-Image /RestoreHealth"
reboot
run "sfc /scannow"
reboot
run "sfc /scannow"
reboot
After the second run of sfc no error where reported anymore and typhon32 was working again.
4 months 1 week ago #11918 by Sternas Stefanos
have fun
2 months 3 weeks ago #12690 by khushbu
Replied by khushbu on topic Problems in WINDOWS 10 and DIRECTX (d3d9.dll)
If the problem is occur in dll file when you try to access the file in windows 10 but it shows an error then download d3d9.dll file and after that saved the settings of dll file carefully in the computer.
