× Components and Libraries for Graphics Development, discussions, problems and suggestions.
Question How to draw on Cursor
  • Roman
  • Topic Author
  • Junior Boarder
  • Junior Boarder
10 months 6 days ago - 10 months 6 days ago #11506 by Roman
How to draw on Cursor was created by Roman
Hi All!
I need to runtime modify cursor image. Drawing by cursor Canvas do not work correctly: any painting make image transparent.
On the FPC-forum helped me with this code:
procedure TToolFill.UpdateImage;
  Cur : TCursorImage;
  Bitmap : PBitmapInfo;
  FillColor : TRGBQuad;
  procedure Square(x, y, w : integer);
     I, J : Integer;
    // квадратик
    with FillColor do begin
       rgbRed := Red(fColor);
       rgbGreen := Green(fColor);
       rgbBlue := Blue(fColor);
       rgbReserved := $FF;
    for I := y to y+w do begin
      for J := x to x+w do begin
        Bitmap^.bmiColors[I * Cur.Width + J] := FillColor;
  Cur := TCursorImage.Create;
  Cur.LoadFromResourceID(HINSTANCE, CurId);
  GetMem(Bitmap, SizeOf(TBitmapInfoHeader) + Cur.Width * Cur.Height * SizeOf(TColor));
  with Bitmap^.bmiHeader do begin
    biSize := SizeOf(TBitmapInfoHeader);
    biWidth := Cur.Width;
    biHeight := Cur.Height;
    biPlanes := 1;
    biBitCount := 32;
    biCompression := BI_RGB;
    biSizeImage := biWidth * biHeight * SizeOf(TColor);
  GetDIBits(Cur.Canvas.Handle, Cur.BitmapHandle, 0, Cur.Height, @(Bitmap^.bmiColors), Bitmap, DIB_RGB_COLORS);
  Square(Cur.Width - 9, Cur.Height - 9, 8);
  SetDIBits(Cur.Canvas.Handle, Cur.BitmapHandle, 0, Cur.Height, @(Bitmap^.bmiColors), Bitmap, DIB_RGB_COLORS);
  FreeMem(Bitmap);
  Screen.Cursors[CurId] := Cur.ReleaseHandle;
  Cur.Free;
  WorkScreen.PB.Cursor := CurId;
But this code not flexible becouse drawind curves, ellipses and angled lines need more work.
My question to the connoisseurs is this: is there any way to do the same thing on the principle of drawing on canvas?
For example, instead of the above procedure Square(..) use something like SomeObj.Canvas.FillRect (...)?
Last edit: 10 months 6 days ago by Roman.
10 months 6 days ago - 10 months 6 days ago #11507 by Sternas Stefanos
Replied by Sternas Stefanos on topic How to draw on Cursor
TCursorImage has Canvas
so this must work
procedure test;
 var Cur : TCursorImage;
  cur.Canvas.FillRect();
  cur.Canvas.some
  Cur.Free;
Last edit: 10 months 6 days ago by Sternas Stefanos.
  • Roman
  • Topic Author
  • Junior Boarder
  • Junior Boarder
10 months 6 days ago #11508 by Roman
Replied by Roman on topic How to draw on Cursor
Sternas Stefanos wrote: so this must work
Must, but do not work :)
If cursor is 32-bit-color image any drawing as Canvas.LineTo or Canvas.FillRect or any other make original image transparent.
The image above is obtained by the following code (red circle is background):
  with Cur.Canvas do begin
    Brush.Style := bsSolid;
    Brush.Color := clBlue;
    FillRect(10,10,21,21);
  Cur.Free;
10 months 6 days ago #11509 by Sternas Stefanos
so the TCursorImage.Canvas work OK
Try
  Cur.Transparent:=false or true;
  Cur.TransparentColor:=
  Cur.TransparentMode:=
