Bug in Typhon32 IDE 12 years 10 months ago #4708
  • Javor
  • Javor's Avatar Topic Author
Typhon32 IDE under Windows XP hangs when changing language. Here's my setup and the problem:
OS - Windows XP
IDE - Typhon IDE v 4.5 / 01.11.2013
FPC version: 2.7.1
SVN version: 42844
Problem: when I change input language (in my case EN -> BG) IDE hangs, has to be force closed and restarted. I use the integrated languages in XP. Happens only with Typhon IDE. No problem with Lazarus IDE.
Bug in Typhon32 IDE 12 years 10 months ago #4709
We fix this
Bug in Typhon32 IDE 12 years 10 months ago #4710
  • DiMiTRiOS
  • DiMiTRiOS's Avatar
Yoy must enable extended text services .!
(solved from 4aiman and works for me )
AI can not win the natural stupidity
The following user(s) said Thank You: Javor
Bug in Typhon32 IDE 12 years 10 months ago #4711
  • Javor
Confirmed, it works now! Thanks, dryplace.
Keep up the good work, guys! CT is awesome project.
