× General Forum discussions that don't fit in any of the other specific forum categories, help etc.
Question TDCP_sha256 decode hash
  • Md. Shariful Alam Khan
  • Topic Author
  • Junior Boarder
  • Junior Boarder
2 months 1 week ago #11814 by Md. Shariful Alam Khan
TDCP_sha256 decode hash was created by Md. Shariful Alam Khan
Is there a way to decode hash from TDCP_sha256?
2 months 1 week ago #11816 by Sternas Stefanos
Replied by Sternas Stefanos on topic TDCP_sha256 decode hash
Please Sir
look at pl_DCP and pl_HashLib4Pascal libraries
2 months 4 days ago - 2 months 4 days ago #11822 by Tigr
Replied by Tigr on topic TDCP_sha256 decode hash
I think you will find it useful depending on the task!
here is a simple implementation without HMAC:
uses DCPsha256, cHash;
///for cHash
SHA256DigestToHex(CalcSHA256('some text'));////:String
function DigestToStr(Digest: array of byte): string;
i: Integer;
Result := '';
for i := 0 to Length(Digest)-1 do
Result := Result + LowerCase(IntToHex(Digest, 2));
function GetStringHash(Source: string): string;
Hash: TDCP_sha256;
Digest: array[0..31] of Byte;
Hash := TDCP_sha256.Create(nil);
Hash.Init;
Hash.UpdateStr(Source);
Hash.Final(Digest);
Hash.Free;
Result := DigestToStr(Digest);
File Name: cDefines.zip
File Size:29 KB
Last edit: 2 months 4 days ago by Tigr.
2 months 4 days ago #11823 by Sternas Stefanos
2 months 4 days ago - 2 months 4 days ago #11824 by Tigr
Sternas, I have a question for you of a slightly different nature... Why, when creating an array of strings[64] with above 30 000 000 ide just compiles but does not run the program?
ide64, memory 32 GB
/ / can somewhere that it is necessary to expose?
c:array[1..30000000] of string[64]; // I need 50kk (((((
2 months 4 days ago #11825 by Sternas Stefanos
First of all my friend
c:array[1..30000000] of string[64]; it's not good programming sample :(
For so big data we use TMemorySream or Streams or TList or TStringsList or a small Database, etc
Anyway: Did you try to run your app with NO Debug data ?
2 months 4 days ago #11826 by Tigr
//if 50kk
gdb command:
"- exec-run"
return an error:
",msg="Error creating process C:\\...\315\356\342\340\377 \357\340\357\352\340\\project1.exe, (error 193).""
2 months 4 days ago #11827 by Sternas Stefanos
Did you try to run your app with NO Debug info ?
a simple run ?
2 months 4 days ago #11828 by Tigr
I run with Debug info
2 months 4 days ago #11829 by Sternas Stefanos
My suggestion is to
put your programs in a folder containing no spaces
2 months 4 days ago #11830 by Tigr
Question on backfill... when TmemoryStream access to read data will be faster than with the array?
2 months 4 days ago #11831 by Sternas Stefanos
Theoretically: NO
Practically: YES (if you delete,copy,insert, etc data)
2 months 4 days ago - 2 months 4 days ago #11832 by Tigr
Do you have a better solution when working with big data?
2 months 4 days ago - 2 months 4 days ago #11833 by Sternas Stefanos
My Suggestion for
memory Big data, different from each other :
TObjectList info or TFPObjectList info
Last edit: 2 months 4 days ago by Sternas Stefanos.
2 months 4 days ago #11834 by Tigr
Thanks!
2 months 4 days ago #11835 by Tigr
c:array of string[64];
If you use a dynamic array, the program works fine! At the moment, more than 30kk have already been filled, this is the result!
2 months 4 days ago #11836 by Sternas Stefanos
Have fun Sir
