Question CT LAB ver 6.70
1 month 1 week ago #12973 by Sternas Stefanos
Replied by Sternas Stefanos on topic CT LAB ver 6.70
after
VarBaseDockMaster:=TGlassDockMaster.Create(self);
//in your app
// Write
VarBaseDockMaster.LoadDefaultSettings;
until we fix this
1 month 1 week ago #12974 by joony3
Replied by joony3 on topic CT LAB ver 6.70
Sorry Sir,
but nothing changed after adding "VarBaseDockMaster.LoadDefaultSettings;" where you said.
1 month 1 week ago #12975 by Sternas Stefanos
Try to replace
C:\codetyphon\typhon\components\pl_GlassDocking\source\gd_dockingbase.pas
with this one
1 month 1 week ago #12976 by joony3
no...still red lines like before...
1 month 1 week ago #12977 by Sternas Stefanos
More info for your app Sir
1 month 1 week ago #12978 by joony3
See attachment.
It's a modified version of dockpanel1 example in code ocean.
Thanks,
J
1 month 1 week ago - 1 month 1 week ago #12979 by Sternas Stefanos
Sir in your app
the docked forms have custom FormPaint event with clRED color (Pen.Color:=clRed;)
dummyfrm.pas line 64
procedure TSimpleForm.FormPaint(Sender: TObject);
  with Canvas do begin
    Pen.Color:=clRed;   // <<<====== THIS ======
    MoveTo(0,0);
    LineTo(ClientWidth-1,0);
    MoveTo(ClientWidth-1,ClientHeight-1);
    MoveTo(0,ClientHeight-1);
    MoveTo(0,0);
So, red color lines are normal
Last edit: 1 month 1 week ago by Sternas Stefanos.
The following user(s) said Thank You: joony3
1 month 1 week ago #12980 by joony3
so sorry sir for this misunderstanding.
Now I've removed paint event...
Thanks anyway for you speed!
now...another thing...I see the new dock minimize button disappears sometimes...See screenshots.
J.
1 month 1 week ago - 1 month 1 week ago #12981 by Sternas Stefanos
This is default functionality.
Only one form can "Minimize" at the same TGlassDockHostSite
1 month 1 week ago #12982 by Peter Heckert
Replied by Peter Heckert on topic CT LAB ver 6.70
First: Thank you for your great work!
Second: Please look at the attached image; it shows the "as is" state.
I believe, it should be the other way. :-)
1 month 1 week ago - 1 month 1 week ago #12983 by Sternas Stefanos
we fix it
4 weeks 2 days ago #12993 by Sternas Stefanos
We release
LAB CodeTyphon Ver 6.7 Revision 006675
Please test, report and have fun.
The following user(s) said Thank You: xcod, Manos S. Pappas
3 weeks 5 days ago #13000 by Peter Heckert
Compile - Ctrl+F9
and
Build - Shift+F9
both build the project (the EXE file)
3 weeks 5 days ago #13001 by Sternas Stefanos
we will try to fix and this
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
  • Junior Boarder
  • Junior Boarder
2 weeks 3 days ago - 2 weeks 3 days ago #13009 by Klaus Riesterer
Replied by Klaus Riesterer on topic CT LAB ver 6.70
in actual Lab IDE-Hotkey will not work. e.g. no reaction when pressing STRG+Blank or Shift-Strg-Up/Down
Worked fine in 6.6.
It's on Mint 19.1 64 Bit
Last edit: 2 weeks 3 days ago by Klaus Riesterer.
2 weeks 3 days ago - 2 weeks 3 days ago #13010 by Sternas Stefanos
I thing we fix that in current Unreleased Lab CT version
On Debian64 9.6 (now) all are OK
Last edit: 2 weeks 3 days ago by Sternas Stefanos.
2 weeks 4 hours ago #13016 by Sternas Stefanos
We release
LAB CodeTyphon Ver 6.7 Revision 006680 RC3
1 week 5 days ago - 1 week 5 days ago #13017 by Peter Heckert
Thanks and happy new year!
Some quick findings:
Build and compile both build the project.
The assembly window pops up during single step.
This happens preferrably when window event methods are singlestepped or threads are singlestepped.
It does not happen with fpdebug internal.
Windows 10, Typhon 6.7, 64 bit.
Last edit: 1 week 5 days ago by Peter Heckert.
1 week 5 days ago #13018 by Matis A.
Replied by Matis A. on topic CT LAB ver 6.70
after update GDB to 8.2.1 (CT revision 006680) we start full debug test cycles,
we check (again) and FreePascal Source code....
We will NOT release CT 6.7 final, if we don't solve these problems,
all other Lab tasks are closed.
CodeTyphon Core Programmer
The following user(s) said Thank You: Peter Heckert
1 week 3 days ago #13019 by Leonid
Replied by Leonid on topic CT LAB ver 6.70
Changes from previous releases.
Example: CodeOcean/Database/samples/sqlite3lookupcombobox/ runtime error.
Compiling a project without errors, but running causes an exception ' ESyncObjectExeption '
with the message ' Failed to create OS basic event with name "" '
If you add a line ' {$DEFINE UseCThreads} 'to the file ' sqlite3lookupcombobox.ppr '
the program works fine
It seems to be related to pl_ZeosDBO ZClasses:
{ TZThreadTimer }
constructor TZThreadTimer.Create;
inherited Create;
FSignal := TSimpleEvent.Create;
Thanks to all your team for a great tool.
It's on Linux 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
Typhon 6.7 r60042 FPC 3.3.1 x86_64-linux-gtk2
