Question CT LAB ver 6.60
3 months 3 weeks ago - 3 months 3 weeks ago #11937 by Sternas Stefanos
Replied by Sternas Stefanos on topic CT LAB ver 6.60
We finish tests on MACOS High Sierra 10.13.6
and one screen with
CTCenter for Cocoa platform,
Typhon IDE for GTK2 platform
Last edit: 3 months 3 weeks ago by Sternas Stefanos.
3 months 3 weeks ago #11939 by Sternas Stefanos
New LAB release,
CodeTyphon 6.60 Revision 6550 RC1
with SVN/Trunk FreePascal 3.3.1
Please test and report...
3 months 3 weeks ago #11942 by fredvs
Replied by fredvs on topic CT LAB ver 6.60
Hello Sternas.
On last Manjaro multi-arch 64 bit.
OK, I did a update of CT.
All compile ok but when running:
$ codetyphon
First it complain that (even after installing System Libraries):
codetyphon: error while loading shared libraries: libQtWebKit.so.4: cannot open shared object file: No such file or director
So I did manually install ibQtWebKit.
But now it complain for this:
codetyphon: error while loading shared libraries: libjpeg.so.62: cannot open shared object file: No such file or directory
I did install it with:
$ sudo pacman -S libjpeg
But still error message: error while loading shared libraries: libjpeg.so.62.
3 months 3 weeks ago - 3 months 3 weeks ago #11943 by Sternas Stefanos
This is Manjaro Linux Problem
My suggestion,
for real MultiArch and MultiPlatform Linux,
look at Debian 9.x or Fedora 28
Anyway, we test now CT on the latest Manjaro
3 months 3 weeks ago #11944 by Fernando
Replied by Fernando on topic CT LAB ver 6.60
Downloaded, compiled and run IDE, compiling a small project, all OK here.
Linux Mageia 6 x64
Cheers
3 months 3 weeks ago #11945 by Sternas Stefanos
Thanks SIr
3 months 3 weeks ago - 3 months 3 weeks ago #11946 by fredvs
Hello Sternas.
OK, compiling Typhon64-GTK and Typhon32-Qt4 gives both applications running.
For compiling + running Typhon64-Qt4/Qt5 gives dependencies-problem on my Manjaro-Arch.
But this is not the problem of CT. ;-)
By the way, what are the main new features in fpc 3.3.1. vs fpc 3.0.x ?
Many thanks.
Last edit: 3 months 3 weeks ago by fredvs.
3 months 3 weeks ago - 3 months 3 weeks ago #11947 by Sternas Stefanos
FreePascal 3.0.x is very old "SVN Tag"
now FreePascal 3.3.1 has
--More packages.
--So many many bugs fixes and improvements, freepascal team works 24/7 for this.
--Pas2JS tool info (From Pascal to JavaStript) look at your CT 6.6.0 CodeOcean/Fp_JavaScript samples
FreePascal with this ability is one level up from other negative programming languages
you can write Pascal Web Client Applications,
you can write Pascal games for WEB with WebGL.
--Webidl2pas tool.
--Better old pascal compilers support Delphi, Turbo Pascal etc.
--Our Support, we test and test every FPC trunk revision to all host support OSes,
and this is Quality.
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
  • Junior Boarder
  • Junior Boarder
3 months 3 weeks ago - 3 months 3 weeks ago #11948 by Klaus Riesterer
Replied by Klaus Riesterer on topic CT LAB ver 6.60
Sample fpReportdesign causes an error when selecting DB-type
Mint 19 Cinnamon, CT LAB 6.60 (actualized today)
... I do an actual download again just now and report later ...
Last edit: 3 months 3 weeks ago by Klaus Riesterer.
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
3 months 3 weeks ago #11949 by Klaus Riesterer
Downloaded a few minutes ago - fpReport now works again - ThankYou
3 months 3 weeks ago #11950 by Sternas Stefanos
have fun
3 months 3 weeks ago #11951 by fredvs
Hello Sternas.
Thanks for your light !
About Qt4/Qt5 for Manjaro 64 bit, here (maybe) some help:
forum.manjaro.org/t/problems-with-qt4-qt5/55756
3 months 3 weeks ago - 3 months 3 weeks ago #11952 by fredvs
OK, after a big battle, finally 64 bit Qt4 and Qt5 applications can run on Manjaro (see forum.manjaro.org/t/problems-with-qt4-qt5/55756 ).
But this is a advice of one of the gurus:
Qt4 has been EOL for several years. It is unmaintained and has been removed from Arch (and Manjaro).
All maintained applications have switched, or are switching, to Qt5.
You should probably look for maintained applications rather than trying to use old stuff in a rolling-release distro.
If you’re developing your own applications, you should switch to Qt5.
3 months 3 weeks ago - 3 months 3 weeks ago #11953 by Sternas Stefanos
Manjaro based to ArchLinux
ArchLinux has old QT4 libraries, QT4 pkg it's unmaintained
In our tests yesterday, on Manjaro and ArchLinux,
CTC can build TyphonIDE of QTK2 and QT5 without problem,
QT4 has problem
My suggestion again,
for real MultiArch and MultiPlatform Linux programming,
look at Debian 9.x, Fedora 28, Mageia 6 etc
3 months 3 weeks ago - 3 months 3 weeks ago #11954 by fredvs
Hello Sternas.
OK, I will follow your advice and install Debian 9.
About Manjaro, it was because of this: distrowatch.com/
Take a look at statistics (right-middle side of the page) ---> Manjaro is first.
I do not like Mint anymore (I did have bad battle with the core developers).
OK, I will try Debian 9.
3 months 3 weeks ago - 3 months 3 weeks ago #11955 by fredvs
@Klaus : be **very** careful with Mint + Cinnamon : --->
github.com/linuxmint/Cinnamon/issues/7636
github.com/linuxmint/Cinnamon/issues/7622
github.com/linuxmint/Cinnamon/issues/7641
github.com/linuxmint/muffin/issues/325
3 months 2 weeks ago - 3 months 2 weeks ago #11956 by Sternas Stefanos
I use Linux for professional reasons from 1992
Windows and SunOS (Solaris) from 1987
FreeBSD from 1994
At this time of the OS Cosmos
Linux Galaxy has:
-Primary Distributions or for our LAB "Linux Families" info
-and Secondary or Customization Distributions
After Million of tests, (many hard disks, CPUs and Motherboards "died" on these tests :ohmy: )
RedHat, Debian and Mandriva Families are the
only Multi-Architecture and Multi-Platform Distributions
For "Programming" I always Suggest Primary Distributions,
for "Using" I can suggest and a Customization Distribution (like Ubuntu)
Mint-Linux and Manjaro are Secondary-Customization Distributions of Debian-Ubuntu and ArchLinux.
It's your choice ... :)
Last edit: 3 months 2 weeks ago by Sternas Stefanos.
3 months 2 weeks ago - 3 months 2 weeks ago #11957 by fredvs
At this time of the OS Cosmos, Linux Galaxy has...
Excellent Linux Distros Universe explanation and you convert me, i will use a Primary Distribution/Multi-Arch-Platform.
It seems to me that Debian 9.x will be my new lover.
For FreeBSD, it is easier, I use polYdev .
Many thanks Sternas and big congrats for last CT 6.60.
Last edit: 3 months 2 weeks ago by fredvs.
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
3 months 2 weeks ago #11958 by Klaus Riesterer
@Fredvs
None of this problems here but thank you for the infos.
3 months 2 weeks ago #11959 by fredvs
@Klaus.
Ha, happy that all work for you.
Huh, may I ask you if a GTK2 and/or -GTK3 application can switch a window from minimized state to normal state programmatically on your Linux Mint Cinnamon ?
Maybe they finally fix the bug (and so sorry for the noise).
