Question CT LAB ver 6.50
5 months 3 weeks ago #11556 by Sternas Stefanos
Replied by Sternas Stefanos on topic CT LAB ver 6.50
Download link for CT 6.15
here
5 months 1 week ago #11578 by Sternas Stefanos
We release LAB CodeTyphon ver 6.50 revision 006430.
Please, try and report
Have fun
5 months 1 week ago #11593 by AntonyRF
Replied by AntonyRF on topic CT LAB ver 6.50
You nice =)
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
5 months 1 week ago #11596 by Klaus Riesterer
Replied by Klaus Riesterer on topic CT LAB ver 6.50
Sir Thank You!
Still no problems found with my big project using revision 006430
5 months 1 week ago #11597 by Sternas Stefanos
have fun
5 months 6 days ago #11603 by Fernando
Replied by Fernando on topic CT LAB ver 6.50
Using Typhon 6.50, selecting Package -> New Package, I get a message box (please note, locale is Spanish):
"IDE de Typhon32 v6.5 - Bind
[Content]
"PackageEditor_Nuevo paquete1" is not a valid component name.
Press OK to ignore and risk data corruption.
Press Abort to kill the program.
[Aceptar] [Abortar]"
The same happens with typhon32 and 64 under windows 7, and typhon64 under mageia linux 6.
No other problems found so far.
5 months 6 days ago #11604 by Sternas Stefanos
we will check and fix this
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
5 months 4 days ago - 5 months 4 days ago #11611 by Klaus Riesterer
Sadly I had Problems with zeos again. In some cases Zeos runs in an error.
The error kills the program, no further information from debugger available (Shows only zeros).
The error occurs sometimes when doing an update.
With Zeos-package from CT 600 it again works all fine!
I'll try to get more information, but the debugger is not usefull in this state
(CT 6.50 latest release on Mint 18.3 Cinnamon)
Some more Information:
The error occurs sometimes when I change a value in e.g. dbedit but BEFORE doing an update to query!
function BearbeiteAuftragsPosition(IDAuftrag: integer; IDPosition: integer; Neu: boolean): boolean;
  Suchtext: string;
  LastRec: integer;
  PosNeu: integer;
  IDArtikel, IDPreis: integer;
  StSatz, FStSatz: string;
  F: TfrmPosition;
  LDat: boolean;
  with dtmAuftrag do
    if IDPosition = 0 then
      if MessageDlg('Es sind noch keine Positionen vorhanden. Wollen Sie jetzt eine anlegen?', mtConfirmation, [mbYes, mbNo], 0) = mrYes then
        Neu := True
      else
        Result := False;
        exit;
    LDat := False;
    case dtmAuftrag.qryAuftragsListe.FieldByName('auf_typ').AsInteger of
      10, 40, 50, 53, 59: LDat := True;
    if Neu then
      CreateNewPosition(IDPosition);
        10, 40, 50, 53, 59:
          with dtmBasis.Calendar do
            Title := 'Leistungsdatum';
            Date :=now;
            if Execute then
              WriteIniFile('Auftrag', 'Leistungsdatum', FormatDateTime('dd.mm.yyyy', Date));
              ExecSQLDirect(dtmBasis.qrySQL, 'UPDATE AuftragsPositionen SET apo_leistungsdatum ="' + FormatDateTime(
                'yyyymmdd', Date) + '" where idauftragsposition=' + IntToStr(IDPosition));
            end
            else
              ShowMessage('Heutiges Datum wird als Leistungsdatum übernommen!');
    if IDPosition > 0 then
      OpenSQLSet(qryPosition, 'Select * from AuftragsPositionen where idauftragsposition = ' + IntToStr(IDPosition));
      BerechnePosition;
      F := TfrmPosition.Create(nil);
      F.dbdLeistungsdatum.Visible := LDat;
      F.lblLeistungsdatum.Visible := LDat;
      F.dbeMitarbeiter.Visible := LDat;
      F.lblMitarbeiter.Visible := LDat;
      if qryPositionsListe.FieldByName('colorn').AsVariant <> NULL then
        F.pnlHeader.Color := qryPositionsListe.FieldByName('colorn').AsVariant;
      if qryAuftragsListe.FieldByName('fk_auftragssteuerart').AsInteger = 3 then // §13b UStG
        F.lblUStG.Visible := True;
        F.dblSteuersatz.Enabled := False;
      end
      else
        F.lblUStG.Visible := False;
        F.dblSteuersatz.Enabled := True;
      try
        F.ShowModal;                                                          // ALL OK UNTIL NOW - form is shown. DoSave is public
        if DoSave then
          if qryPosition.State = dsEdit then
            qryPosition.ApplyUpdates;
          if qryPosition.FieldByName('fk_posart').AsInteger=2 then
             ExecSQLDirect(dtmBasis.qrySQL,'Update AuftragsPositionen set apo_artikelgruppe=0 ,  apo_herstellernummer="", apo_seriennummer="",'+
             'apo_mengeneinheit="", apo_staffel=0, apo_zeit=0, apo_lohn=0, apo_service=0, apo_material=0, apo_geraet=0, apo_fremdleistung=0,'+
             'apo_menge=0, apo_netto_vk=0, apo_rabatt=0,  apo_mitarbeiter="" '+
             'where idauftragsposition=' + qryPosition.FieldByName('idauftragsposition').AsString);
          qryPositionsListe.Refresh;
          qryPositionsListe.Locate('idauftragsposition', qryPosition.FieldByName('idauftragsposition').AsInteger, []);
          Result := True;
        end
        else
          qryPosition.CancelUpdates;
          Result := False;
      finally
        FreeAndNil(F);
procedure TfrmPosition.btnSpeichernClick(Sender: TObject);
  DoSave := True;
  Close;                                              // <<<<<<<<<<<<<<<<<<<<<<<<<<< THE ERROR RISES HERE
Last edit: 5 months 4 days ago by Klaus Riesterer.
5 months 4 days ago - 5 months 4 days ago #11612 by Sternas Stefanos
Please, if you can give more info
PS: Put a break point to
DoSave := True;
line and then click Step intro (F7)
until you find the problem
Last edit: 5 months 4 days ago by Sternas Stefanos.
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
5 months 4 days ago #11613 by Klaus Riesterer
Hallo Sternas
I did that but as mentioned when executing close the debugger pops up with only Zeros ...
4 months 3 weeks ago #11619 by Vitaly
Replied by Vitaly on topic CT LAB ver 6.50
Hello, everybody!
It seems that Zeos is rather old in LAB version: -Update pl_ZeosDBO to Ver 6.5.1 Source SVN Rev 4314
As I understood, there were a lot of changes. I need at least rev.4419 (or maybe later).
Can you update it, please!
4 months 3 weeks ago #11620 by Sternas Stefanos
Yes Sir
please give us time
4 months 3 weeks ago #11621 by Sternas Stefanos
pl_ZeosDBO Ver 6.5.2 Source SVN Rev 4513 (now)
The following user(s) said Thank You: Vitaly
4 months 3 weeks ago - 4 months 3 weeks ago #11623 by Vitaly
Sternas Stefanos wrote: pl_ZeosDBO Ver 6.5.2 Source SVN Rev 4513 (now)
Give me a hint, please. I do not see new Lab version in my CT Update Manager.
I didn't see the attached file at first. Thank you very much!
Last edit: 4 months 3 weeks ago by Vitaly. Reason: upd
4 months 1 week ago #11665 by Sternas Stefanos
We release LAB CodeTyphon ver 6.50 revision 006450.
Have fun
The following user(s) said Thank You: Fernando
4 months 1 week ago #11669 by Fernando
Hello Sir,
New version works generally well. However, this issue:
www.pilotlogic.com/sitejoom/index.php/fo...-6-50?start=10#11603
is still present.
Also, this one seems to be yet unfixed:
www.pilotlogic.com/sitejoom/index.php/fo...ar-in-designer#11327
Keep the good work
4 months 1 week ago - 4 months 1 week ago #11671 by Sternas Stefanos
we are working on these problems
please give us time...
Last edit: 4 months 1 week ago by Sternas Stefanos.
4 months 1 week ago #11672 by Fernando
OK, thanks
4 months 1 week ago #11673 by fredvs
Replied by fredvs on topic CT LAB ver 6.50
Perfect, works out-of-the-box. even multi-arch with Linux Mint.
About Lazarus to CT conversion.
I did use the CT converter.
*.lpi
> *.ctpr
*.lpr
> *.ppr
But in last CT 6.50 it seems that *.lfm are converted too into *.frm.
Is it a difference with the code lfm vs frm or is it only a other extension name ?
Thanks.
4 months 1 week ago #11674 by Sternas Stefanos
"Is it a difference with the code lfm vs frm or is it only a other extension name ?"
only an other extension for this CT version
