Important CT LAB ver 6.30
1 year 1 month ago #11072 by Sternas Stefanos
Replied by Sternas Stefanos on topic CT LAB ver 6.30
xcod wrote: hi
please! add FBDataSet
Is a easy-to-use library of Lazarus, components for work with InterBase and Firebird.
shamangrad.ru/project.php?act=view&prj=FBDataSet
svn.shamangrad.ru/FBDataSet
FBDataSet is in the CodeTyphon from version 6.0
pl_FBDataSet package
1 year 1 month ago #11073 by xcod
Replied by xcod on topic CT LAB ver 6.30
sorry
I did not notice
1 year 1 month ago #11074 by Sternas Stefanos
We update our WIKI pages now :)
  • Manos S. Pappas
  • Manos S. Pappas's Avatar
  • Junior Boarder
  • Junior Boarder
1 year 1 month ago #11075 by Manos S. Pappas
Replied by Manos S. Pappas on topic CT LAB ver 6.30
Update Manager on CodeTyphon QT5 Control Centre under Linux (Arch Linux) does not download files unless the mouse pointer is constantly moving over the cmdbox area.
This bug was introduced with CT 6.00.
Thank you very much in advance.
Best Regards,
Manos S. Pappas
1 year 1 month ago #11076 by Sternas Stefanos
please give us time to test and fix
Always you can use GTK2 or QT4 CTCentrer
The following user(s) said Thank You: Manos S. Pappas
1 year 1 month ago - 1 year 1 month ago #11083 by Sternas Stefanos
Some LAB Good News.. :)
-ADD pl_SDL2 package to Typhon IDE Components System.
-ADD pl_OpenGLES package to Typhon IDE Components System.
ctGLES1.pas and ctGLES2.pas files Auto-Build from Khronos OpenGLES registry files (gl.xml, egl.xml) like pl_Vulkan package.
-Total reconstruct pl_OpenGL package
ctGL.pas file now Auto-Build from Khronos OpenGL registry files (gl.xml,glx.xml,wgl.xml) like pl_Vulkan package.
CodeTyphon libraries like:
-pl_AsphyreSphinx
-pl_ORCA3D
-pl_OpenGLADV
-pl_nxPascal
use now the new OpenGL files...
have fun....
Last edit: 1 year 1 month ago by Sternas Stefanos.
1 year 3 weeks ago - 1 year 3 weeks ago #11085 by Sternas Stefanos
We release CT 6.30 Final
After a lot of work and tests, Programming "Magic" and "Power" is here
From our Lab Core Team
Have Fun...
Last edit: 1 year 3 weeks ago by Sternas Stefanos.
1 year 3 weeks ago #11086 by fredvs
Replied by fredvs on topic CT LAB ver 6.30
Hello Sternas.
I have problem to install last version 6.3 in Linux Mint 17.
1 year 3 weeks ago #11087 by Alex
Replied by Alex on topic CT LAB ver 6.30
Hello. I have a question. I tried to build cross element armel-linux, but got an error
      Stage 1: Build FreePascal Cross Compiler Executable
Makefile:215: *** The Makefile doesn't support target armel-linux, please run fpcmake first.  Stop.
  [ERROR]:  win32 Cross compiler ppcrossarm.exe NOT Builded
what i can do with this?
Thank you in advance.
1 year 3 weeks ago - 1 year 3 weeks ago #11088 by Sternas Stefanos
fredvs wrote: Hello Sternas.
Sir, please try to install p7zip
sudo apt-get install p7zip
or
sudo apt-get install 7zip
CT6.30 has the latest p7zip, this version of p7zip works only with the new Linux Kernels (>4.2)
CT will use the local copy of p7zip if exists.
LinuxMint 17.x use old Linux Kernel
Screen Lab from LinuxMint 18.2 Sonya (now) with OpenGL 4.6 Tests...
1 year 3 weeks ago - 1 year 3 weeks ago #11089 by Sternas Stefanos
Alex wrote: Hello. I have a question. I tried to build cross element armel-linux, but got an error
Please Sir give us more info
your Hosts OS etc...
if you have Windows please use FPC32 for cross-build
1 year 3 weeks ago #11096 by fredvs
or
Hello Sternas.
OK, I get it.
This does the trick:
$ cd /the/directory/of/CodeTyphonIns (---> this was needed)
$ sudo /the/directory/of/CodeTyphonIns/install.sh
I know that normally "sudo" must not be used.
But if I do not use "sudo" ---> "Error, sudo is not installed". (???)
When using sudo /the/directory/of/CodeTyphonIns/install.sh --->
0) Install CodeTyphon Studio + 8) Remove and Build ALL --->
All compiles and install ok.
After some test, very good impression ;-)
About fpc 3.1.1, a litle bemol: for every project, if you choose optimisation -O2 -->
Error: /usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcx64 can't be executed, error message: Failed to execute "/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcx64", error code: -11
But with optimisation -O3 --> OK.
Other thing.
About installing CT-Windows on a Linux system.
Perfect, you have added the missing ".bat" extensions in all the Windows-scripts.
Now ---> wine x_CodeTyphon_Remove_Make_ALL.bat --> install CT-Windows on my Linux mint system perfectly. ---> Wow and many thanks.
Huh, fpc 3.1.1 is not fully compatible with fpc 3.0.x. But this is a other story.
Thanks Sternas.
1 year 3 weeks ago #11097 by Sternas Stefanos
and have fun
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
  • Junior Boarder
  • Junior Boarder
1 year 2 weeks ago #11124 by Klaus Riesterer
Replied by Klaus Riesterer on topic CT LAB ver 6.30
Big problem with 6.30 !
My project was developed with CT6.00 and all works fine. Yesterday I updated to CT6.30. My system is linux mint 18.3.
What happens:
After starting the PC I can open and compile my application - it runs.
When I close the application I get an exception and I can't restart it until I restart my system:
TApplication.HandleException Access violation
Stack trace:
$0000000000468D66 FORMCREATE, line 30 of INCLUDES/ctrmenhaupt.inc
$000000000044F475 DOCREATE, line 939 of include/customform.inc
$000000000044D39A AFTERCONSTRUCTION, line 149 of include/customform.inc
$0000000000455547 CREATE, line 3156 of include/customform.inc
$000000000045ECE1 CREATEFORM, line 2223 of include/application.inc
$00000000004201BF main, line 68 of ctrboss.ppr
Heap dump by heaptrc unit
45402 memory blocks allocated : 7110519/7218584
45393 memory blocks freed : 7110052/7218104
9 unfreed memory blocks : 467
True heap size : 1474560
True free heap : 1472640
Should be : 1472928
There where no problems with CT6.00, all blocks where freed on exit.
Any idea where and how I can find the reason for that?
1 year 2 weeks ago #11125 by Sternas Stefanos
Sir more info ?
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
1 year 2 weeks ago - 1 year 2 weeks ago #11127 by Klaus Riesterer
See later posts
Last edit: 1 year 2 weeks ago by Klaus Riesterer.
1 year 2 weeks ago #11128 by Sternas Stefanos
My sugestion:
1)Copy ZEOS from CT6.00
2)Convert old ZEOS files with CTCenter=>CodeTyphon=>Convert OLd ....
3) Replace ZEOS in CT6.3 with OLD ZEOS
4)Test CT 6.3 with OLD ZEOS...
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
1 year 2 weeks ago - 1 year 2 weeks ago #11130 by Klaus Riesterer
Hi Sternas,
I installed again 6.30 (complete reinstall, not update) and walk through my program step by step. What I got in Debug-Console is now different from last time:
(ctrboss:3924): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[FORMS.PP] ExceptionOccurred
Sender=EAccessViolation
Exception=Access violation
Stack trace:
$00007FFFF693B7ED
$000000000063BB87 NEWDEVICECONTEXT, line 766 of gtk2/gtk2def.pp
$00000000004991D2 NEWDC, line 5471 of gtk2/gtk2widgetset.inc
$00000000004A93A5 SAVEDC, line 7493 of gtk2/gtk2winapi.inc
$0000000000585B10 SAVEDC, line 830 of include/winapi.inc
$00000000005A5BCA SAVESTATE, line 1772 of include/canvas.inc
$00000000005A5AD6 TEXTEXTENT, line 1790 of include/canvas.inc
$00000000005A5C08 TEXTWIDTH, line 1809 of include/canvas.inc
$0000000000E7077E TEXTBOUNDS, line 911 of source/rlutils.pas
$0000000000E48070 CALCSIZE, line 7801 of source/rlreport.pas
$0000000000E43CC6 ADJUSTBOUNDS, line 6479 of source/rlreport.pas
$0000000000E4652C SETAUTOSIZE, line 7354 of source/rlreport.pas
$0000000000E47A1C CREATE, line 7717 of source/rlreport.pas
$0000000000E49085 CREATE, line 8016 of source/rlreport.pas
$00000000004D2BA9
$00000000004D3205
$00000000004D2E74
Stack trace:
$00007FFFF693B7ED
$00000000004D2BA9
$00000000004D3205
$00000000004D2E74
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
1 year 2 weeks ago - 1 year 2 weeks ago #11131 by Klaus Riesterer
Next Step:
I located a form with FortesReport generating the g_object_unref: assertions.
I commented this page and now the program starts - but on close i get unfreed memory block with luirest.pas
691290 memory blocks allocated : 139941829/142027976
691286 memory blocks freed : 139941717/142027864
4 unfreed memory blocks : 112
True heap size : 3276800
True free heap : 3276032
Should be : 3276176
Call trace for block $00007FFFEE8D4200 size 32
$0000000000D67A59 LUIRESTFASTCGI_$$_init$, line 49 of source/luirest/luirestfastcgi.pas
$000000000043616C
Call trace for block $00007FFFEE8D4140 size 24
$000000000043616C
Call trace for block $00007FFFEE8D4080 size 32
$0000000000DEFC98
$0000000000D629A9 LUIRESTCGI_$$_init$, line 105 of source/luirest/luirestcgi.pas
$000000000043616C
Call trace for block $00007FFFEE8D3FC0 size 24
$0000000000DEFC98
$000000000043616C
This also appears after removing pl_luicontrols from installed packages !
I did not use any luirest* in my project. All I used (before I removed the luicontrols) was uniqueinstance.
  • Klaus Riesterer
  • Junior Boarder
  • Junior Boarder
1 year 2 weeks ago - 1 year 2 weeks ago #11132 by Klaus Riesterer
I removed the link for pl_luicontrols in Package-Links and it works. All I missed now was TUninqueInstance ...
So I opened the package and compiled it, then I placed TUniqueInstance back on my form and after compiling the project now works and the HeapStack is OK.
(Not Fortes but I will use freereport in future, because Fortes makes often problems in my project)
Conclusion:
1. Fortes Report makes problems (Access Violation with my report)
2. It was not zeos as mentioned in the earlier post
3. Its better to remove CT and reinstall it completely new instead of doing an update
4. I like CT again ;-) - Great work - Thank you Sir!
