× CodeTyphon Cross-Build Development, discussions and problems
Question Cross compile smart linking issues on Win64 for RPI3
  • Sanogo
  • Topic Author
  • Fresh Boarder
  • Fresh Boarder
1 month 1 week ago #12946 by Sanogo
  • Hi, I installed CT 6.6 (latest stable version on Windows) and tried to cross compile a very simple sample project from Windows to RPI3 using FPC32.
    When I compile in Debug mode, everything works fine but when I try to compile in Release mode, compilation fails with a certain error message about linking.
    I narrowed down the issue to smartlinking when cross compiling from Win64 to RPI3 using the FPC32 compiler.
    If I disable smartlinking in Release mode, everything including linking works beautifully.
  • Please Log in or Create an account to join the conversation.
    • Sanogo
    • Topic Author
    • Fresh Boarder
    • Fresh Boarder
    1 month 1 week ago #12949 by Sanogo
    Any help guys?
    1 month 1 week ago #12950 by Sternas Stefanos
    Replied by Sternas Stefanos on topic Cross compile smart linking issues on Win64 for RPI3
    can you give us more info for you project ?
    • Sanogo
    • Topic Author
    • Fresh Boarder
    • Fresh Boarder
    1 month 1 week ago #12951 by Sanogo
    Sternas Stefanos wrote: Thanks Sir
    Thanks for replying Sir, it's just a simple Lazarus Form Project. See it attached below
    1 month 1 week ago - 1 month 1 week ago #12953 by Sternas Stefanos
    your project don't define arm-linux Platform more Info
    for Pi3 my suggestion is GTK2
    So, you build your project for Pi3 arm-linux but for Win32 Platform
    with all Debug, Release and Default modes of your project.
    CodeTyphon Form applications have TargetCPU, TargetOS and TargetPlatform
    Last edit: 1 month 1 week ago by Sternas Stefanos.
    • Sanogo
    • Topic Author
    • Fresh Boarder
    • Fresh Boarder
    1 month 1 week ago #12955 by Sanogo
    Hi, I followed your suggestions yet the problem remains, please do note that the project builds and links fine if I select debug mode or disable the "Link smart (-XX) option in Release mode, but if I enable "Link smart (-XX) option in any build mode, linking fails.
    I have repeated it over and over again.
    • Sanogo
    • Topic Author
    • Fresh Boarder
    • Fresh Boarder
    1 month 1 week ago #12956 by Sanogo
    Sternas Stefanos wrote: Sir
    attached below is image proof.
    1 month 1 week ago #12957 by Sternas Stefanos
    So, you want "Smart Link" in a CrossBuild procedure ?
    • Sanogo
    • Topic Author
    • Fresh Boarder
    • Fresh Boarder
    1 month 1 week ago #12958 by Sanogo
    Sternas Stefanos wrote: So, you want "Smart Link" in a CrossBuild procedure ?
    Yes, is this not possible?
    Because it works for me if I try to smartlink when crossbuilding from Win32 to normal Linux (not ARM).
    1 month 1 week ago #12959 by Sternas Stefanos
    OK, we will try fix this Sir
    The following user(s) said Thank You: Sanogo
    1 month 1 week ago - 1 month 1 week ago #12960 by fredvs
    Did you try to add this parameter at compilation:
    -k--gc-sections
    AFAIK, this parameter is omitted sometime with fpc if
    -XX
    is used.
    For example, if you compile libraries with
    -XX
    smart-linking will not work, you must use
    -k--gc-sections
    parameter to enable smart-linking.
    Last edit: 1 month 1 week ago by fredvs.
    • Sanogo
    • Topic Author
    • Fresh Boarder
    • Fresh Boarder
    1 month 1 week ago #12961 by Sanogo
    fredvs wrote: Hello.
    -k--gc-sections
    -XX
    is used.
    -XX
    -k--gc-sections
    Thanks for the help but unfortunately, it didn't work.
