× CodeTyphon Cross-Build Development, discussions and problems
Question Cross Build Linux 64bit to Linux 32bit failed
  • Md. Shariful Alam Khan
  • Topic Author
  • Junior Boarder
  • Junior Boarder
4 months 2 weeks ago #12024 by Md. Shariful Alam Khan
Cross Build Linux 64bit to Linux 32bit failed was created by Md. Shariful Alam Khan
I did a post about Win32-Linux32 in Cross Build Win32-Linux32 which yet to have a suitable answer. So I tried to do Linux 64bit to Linux 32bit and came out as same as Win32-Linux32 with following error:
/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/i386-linux-ld: cannot find /lib/ld-linux.so.2
ld-linux.so.2 file is available in /usr/local/codetyphon/binLibraries/i386-linux
I badly need to compile a library for Linux 32bit as my Linux host application is 32bit(Firebird 1.5) and I making a Firebird UDF.
4 months 2 weeks ago - 4 months 2 weeks ago #12027 by fredvs
Not sure to understand.
Is your main system Linux 64 bit and do yo want to compile a 32 bit Linux library?
IMHO, the most easy is not to do Cross-compilation but use the 32 bit Typhon in a multi-arch 64 bit system.
To resume: install CodeTyphon with "multi-arch" enabled then, load 32 bit Typhon for compile your 32 bit library.
Last edit: 4 months 2 weeks ago by fredvs.
  • Topic Author
  • Junior Boarder
  • Junior Boarder
4 months 2 weeks ago - 4 months 2 weeks ago #12028 by Md. Shariful Alam Khan
Replied by Md. Shariful Alam Khan on topic Cross Build Linux 64bit to Linux 32bit failed
My main system is 64bit and trying to compile 32bit.
I tried to install 32bit IDE but got following error in Ubuntu Budgie 64-bit with 6GB of RAM and with Multi-Arch enabled
make -C packager/registration
make[1]: Entering directory '/usr/local/codetyphon/typhon/packager/registration'
/bin/rm -f ../units/i386-linux/fcllaz.ppu
/usr/local/codetyphon/fpc/fpc32/bin/i386-linux/ppc386 -MObjFPC -Scghi -O1 -g -gl -l -vewnhibq -Fu. -FE. -FU../units/i386-linux -di386 fcllaz.pas
Hint: (11030) Start of reading config file /usr/local/codetyphon/fpc/fpc32/bin/i386-linux/fpc.cnf
Hint: (11031) End of reading config file /usr/local/codetyphon/fpc/fpc32/bin/i386-linux/fpc.cnf
Free Pascal Compiler version 3.1.1 [2018/05/29] for i386
Copyr
Copyright (c) 1993-2018 by Florian Klaempfl and others
(1002) Target OS: Linux for i386
(3104) Compiling fcllaz.pas
Makefile:2803: recipe for target 'fcllaz.ppu' failed
make[1]: Leaving directory '/usr/local/codetyphon/typhon/packager/registration'
Makefile:3268: recipe for target 'registration' failed
mv: cannot stat 'typhon': No such file or directory
mv: cannot stat 'typhonstart': No such file or directory
mv: cannot stat 'typhonbuild': No such file or directory
mv: cannot stat 'tools/ctres': No such file or directory
mv: cannot stat 'tools/ctlrstofrm': No such file or directory
[INFO]: Clean Tools Directory
[ERROR]: Sorry, Typhon32 Small IDE i386-linux-gtk2 NOT Build
Build Typhon32 BIG IDE i386-linux-gtk2 for Linux
[ERROR]: Sorry, Typhon32 from Small-IDE NOT Build
Last edit: 4 months 2 weeks ago by Md. Shariful Alam Khan.
4 months 2 weeks ago - 4 months 2 weeks ago #12029 by Sternas Stefanos
Replied by Sternas Stefanos on topic Cross Build Linux 64bit to Linux 32bit failed
Ubuntu Budgie 64-bit it's NOT MultiArch Distribution,
for this reason we don't enable CodeTyphon MultiArch ability in our CT-OS test info
For true MultiArch and MultiPlatform distributions my suggestion is
Debian 9.x, Fedora 28, Mageia 6 etc. more info
Many "Secondary" Linux Distribution do NOT support MultiArch
it's OS Packages and Libraries problem.
Last edit: 4 months 2 weeks ago by Sternas Stefanos.
